Originally posted by morfic What did you focus on that this shot shows front focus?
Well it was mostly meant as a joke...
The movement involved, the speed, I was going for the hip but off that much is no problem. She's swinging, twisting and this was before the "Duh!" of using AFC rather than AFS...
I am still having AF problems. Started a different thread...
There's a more clear picture of the problem.
I am recalibrating the body and going at it again keeping the images once they are right on and then seeing what happens.
Thanks for the explanation of the system's structure and the expansion to consideration of different light and the effect on AF. One fall out of having such a great camera is that the tolerances are tight. to be able to clearly see the difference in focus caused by different lighting situations is tight.
As for the whole issue of more fine grain selection in the firmware program I am all for that! All the way to reassigning buttons. I only shot in raw so that button, A nice feature, would be good for switching between different user profiles, or as another green button since that one can be a chore to get to sometimes... And more user profiles...
Tired. End of my workweek. will be at this in the morning.
thanks all.
