03-30-2007, 10:54 PM   #1
Firmware for DS
I seem to have an issue in updating my DS.
I have download the firmware 2.02 to my desktop, then copied it to the SD card.
I then place the SD card into the DS, hold down the menu button and turn the camera on, version 1.00 shows up in the display and then it goes to the normal menu and not the update screen described on the Pentax notes that is use the direction dial and ok for yes.
By the way I'm still holding down the menu button, what haven't I done.
Sorry for sounding like an idiot, but what can I say.....
thanks in advance.
Russell
03-30-2007, 11:51 PM   #2
Alvin's Avatar
If you plug your camera into the computer then go into My computer, you should see it as a drive letter. Same effect if you are using a card reader.
Copy the BIN file in that drive and do not go into the folder that's sitting in there.
Now disconnect the camera, turn it off, and try to hold the menu button while turning on the camera again.
Hope that helps
03-31-2007, 12:50 AM   #3
PDL
Did you double click on the downloaded file - the firmware for the *ist Ds is a file named:
FWDC131B.BIN
that is the only file you copy to the SD card then go through the upgrade process.
Firmware is cummulative so you can go from v1.0 to v2.02 without having to go through all the revisons.
PDL
03-31-2007, 04:55 AM   #4
That happened to me on my k10, I had to format the sd card and then copy the file so it would go to root on the card. Erasing the card wasn't enough. Hope this helps.
tom
04-01-2007, 12:22 AM   #5
Arpe's Avatar
Are you sure you copied it to the root directory of the card?
04-01-2007, 12:37 AM   #6
Many thanks to you all, yeap I missed one secton and that was double clicking the ican on the desk top to expand the file to then copy the file FWDC131B.BIN
It worked a treat
button, camera, card, ds, dslr, firmware, menu, photography, sd
Firmware? Naturenut Pentax DSLR Discussion 10 08-03-2010 06:37 AM
K-7 Firmware 1.02 konraDarnok Pentax News and Rumors 1 10-22-2009 08:01 AM
New K7 firmware... dlacouture Pentax DSLR Discussion 9 10-07-2009 10:09 AM
When do we get the new firmware? ottoangel Pentax DSLR Discussion 1 04-19-2009 12:05 PM
Firmware 1.11 benjikan Pentax DSLR Discussion 21 03-15-2007 10:41 AM
All times are GMT -7. The time now is 10:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
