Show Printable Version 47 Likes Search this Thread
05-03-2010, 03:07 PM   #556
Finally got a chance to test out my Pentax K-X attached to the DA* 50-135mm
really impressed, these are non cropped, RAW conversions in Lightroom 2.7 with no sharpening or processing, pure conversion only.
This one shot at dusk, but wanted some depth so f/8 ISO 3200
Trying a bit of flare Again ISO 3200
Really love that film style grain
05-03-2010, 06:34 PM   #557
QuoteOriginally posted by audiobomber Quote
You forgot to mention the ISO.
First set was ISO3200
Second one was ISO1600
05-09-2010, 03:55 AM   #558
JohnBee's Avatar
K20d /ISO6400
A quick snap taken with camera calibration a few weeks back(never got around to looking at it). And so, I thought it would make a good candidate for an ACR v6 /K20D NR processing test.
K20D, ISO6400, f/7.1, 1/500, NR/OFF
Rare wild pony
Larger sized image(for your pixel peeping pleasure...)
05-09-2010, 09:57 AM   #559
Here's a photo from a recent trip to Berlin. Shot handheld with my K-7 and DA* 16-50 wide open at 16mm and ISO800.
PENTAX K-7  Photo
05-09-2010, 01:34 PM   #560
JohnBee's Avatar
Another ISO4000 sample
A few people were asking for slower shutter speeds, but I wasn't able to find anything under 1/250 in the original set.
However.. I did manage to find a 1/60'th ISO4000 sample the same subject in another setup. This one was under a single utility light in my workshop(on my tablesaw).
*** All shots handheld
META: K20D, ISO4000, 1/60, f5.6, NR/OFF
PS. JPEG compression is higher than ave. in this scene, so there are artifacts in a number of areas.
05-10-2010, 12:18 AM   #561
JohnBee's Avatar
K20D ISO6400 Image set
All images taken at ISO6400 and preprocessed in ACR6/CS5
META: K20D, RAW, ISO6400, 28mm, f/5.6, 1/60 - 1/140
click on image for full size
PP TOOLS USED:
  • GordonB's Magenta Cast remover
  • Niksoft Define - Debanding software
  • Adobe Bridge and Photoshop CS5
  • Topaz Denoise 4
TDN 4 is officially the best NR removal tool in my High ISO workflow(period). A spot that held by Noiseware Professional for some time now. I will post my NR comparison samples sometime tomorrow(It's been a long night!).
Thanks for looking.
JB
05-10-2010, 04:28 AM   #562
audiobomber's Avatar
Damnit John, these look great! Now I'm going to have go back and edit all the posts where I said the K20D was unusable at ISO 6400. How long does your regimen take per photo? Can they be batch processed?
05-10-2010, 09:22 AM   #563
Pentaxor's Avatar
JB's post-processed NR ISO6400 images puts the camera NR results to shame.
05-10-2010, 09:35 AM   #564
ISO 1600 @ 1/4000th of a second on a K10d processed with LR3b2
05-10-2010, 10:35 AM   #565
JohnBee's Avatar
It varies, but with TDN4 in the mix it takes longer(8 cores anyone?)... So... in all fairness I'd have to say that if you want to squeeze everything out of your camera noise wise, then you'd best prepared to work for it
Ave PP time: 6-15mins
Ave time if DN4 wasn't as CPU intensive as 3D rendering: 5-8mins.
Having said all that... there is always room for batch processing too.
I estimate that with a good process in place, a shooter could get away with 1-3mins per photo using the advanced noise management techniques used here.
05-10-2010, 10:36 AM   #566
JohnBee's Avatar
Without getting ahead of things... you should see what can be persuaded out of a Kx at 128K using this method.... nothing short of scary...
05-10-2010, 11:09 AM   #567
Pentaxor's Avatar
QuoteOriginally posted by JohnBee Quote
JB, are you saying that the TDN4 is a cpu memory hog? I'm planning to upgrade my system next year as I do every 3 years. although in fairness. my current pc unit is only barely about 2 years old this month and is still very much capable of performing fast processing (although not lightning speed). the only complaint I have with it is so darn noisy and beginning to exhibit some considerable heat due to wear, longevity and dust accumulation.
05-11-2010, 08:49 PM   #568
JohnBee: K20D ISO6400 Image set
I have some K20d 6400 images with which I am delighted, but these here are the best I have seen--anywhere. Thank you so much for sharing--this is eye-opening.
05-12-2010, 02:07 AM   #569
JohnBee's Avatar
QuoteOriginally posted by Pentaxor Quote
JB, are you saying that the TDN4 is a cpu memory hog?...
Absolutely without a doubt
I have done 3D renderings that were faster than Denoise 4, and I always considered that to be intensive. So yes... I definitely think Denoise 4 is way over the top for what it does.
Also.. you have nothing to feel bad about regarding your PC. My workstation core is almost 6 years old(definitely obsolete!), and so you're definitely in better shape than I'll ever be
05-12-2010, 02:09 AM   #570
JohnBee's Avatar
QuoteOriginally posted by Jewelltrail Quote
Thank-you! and you're welcome...
I am working on an ISO6400 night series using the same shooting and PP methods, which I plan on posting here shortly.
Hopefully it give other shooters the incentive to explore new areas of with their gear.
JB
camera, dolphin, dslr, flickr, gallery, iso, photography, post
How to post high resolution photo here? Underbridge Pentax Medium Format 5 12-25-2012 08:56 PM
People K-5 high ISO... how high can we really go... igor Post Your Photos! 2 03-24-2012 01:10 AM
Is there a high iso gallery for K-7? justtakingpics Pentax DSLR Discussion 13 05-31-2010 05:32 PM
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 72 05-10-2010 04:24 PM
Pentax k20d High ISO Photo Gallery PentaxPoke Pentax DSLR Discussion 68 02-18-2009 05:19 AM
All times are GMT -7. The time now is 10:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
