Hi phatbob02
I'll go down your list line by line.
> I just posted the release bracket to help the NewBees.
As I started out my message, I think you did a fine job. But since I take typically several dozen 3 minute frames per night I don't want to hold my finger on a mechanical shutter release. Besides, it's cold out there!
> I purchases the Kx for the sensor, not requiring mods, and because of the price of just over $500.
Fine again. I purchased my K110D new for $349 for astrophotography only. I only used it four days before I opened it up and removed the IR filter. I broke it in the process, had Pentax fix it for $210, still had an astro DSLR for less than the cost of a professionally modified Canon. I used it for several years. It currently has 10,600+ shutter clicks, almost all astro. I don't want you to think I don't like DSLR astrophotography.
> I can live with not turning off NR over 30".
OK, but many can't as you can tell from the number of complaints that has been brought up since the K20D came out. At first many assumed it was an oversight and Pentax would fix that in a firmware upgrade. I think all Pentax cameras with CMOS sensors don't allow NR to be totally disabled like the K1x0Ds.
> And, the Kx external power supply is available.
Pentax K-AC84U AC Adapter Kit.
I wrote there was a kludgey method that uses the same power supply as the K100D. For less than a nickle they could have put a jack on the outside.
> There are people out there getting great results with this camera.
No doubt, the Initial Poster likes it very much.
> I'm "old School" when it comes to AP. I use to hyper my own film.
You're brave. I used a K1000 for several years with refrigerated film. My wife would not let me hyper, "too dangerous to have compressed gas in the house." She was a lab technician and has seen gas cylinders fly across rooms and through walls.
> I own a SBig St-237 and ST-8i.
You have seen the promised land.
> Not everyone has $4500 to shell out for an ST4000XCM, and I think you're comparing apples to oranges.
Absolutely, though I only paid $3750 from OPT. I had reached my limit with the K110D. I was spoiled by the DSLR one-shot-color but wanted to go back to a cooled camera since my ST-7E cut through my light pollution far better than film or DSLR. I can easily capture image MAG 19 galaxies from my MAG 3 sky. I sold the old SBIG to help pay for the new SBIG..
Nothing in my observatory cost me over $900 (the price of my used SCT) except the SBIG. I normally do photography on the cheap, but there was no way around buying an SBIG for me to move forward from the DSLR.
> For NewBee's, this is a great camera to start with.
Perhaps. As I wrote I almost bought one for the features it has over my K110D. Unfortunately it took away features as well.
> If you're thinking of getting into AP, I would recommend a good motor driven mount.
I use my LX200 Classic as a motor drive for a refractor, camera lens, and my 2080 OTA. One motor for all worlds.
On those occasions I go remote for darker sky I use a CG-4 with RA. motor.
> Not all of us need software to turn on this and turn off that.
I'm not sure what you mean by the on and off part. I do use software (or a timer box in the field) to operate the shutter. I also use software to point the scope at a target. With the DSLR that was about it. With the SBIG all camera operation must be with software, it can't function on its own.
My point is you can do astrophotography with a Pentax DSLR, I did for several years (and over 10,600 shutter clicks). I used my K100DS for the lunar eclipse because SBIGs don't do solar system imaging well. I'm just frustrated that Pentax seems to go out of their way to thwart astrophotography. They remove jacks that cost practically nothing. It troubles me when after years of them ignoring requests for a menu option to disable NR someone tricks a camera into factory debug mode and finds such that option exists hidden inside.
I love my Pentax cameras for daytime photos. I can even use my astro modified filterless K110D as a killer IR camera. I measured 100 times faster IR response than my K100Ds
