11-21-2009, 01:26 AM   #1
K-X focus screen
I've tried searching the topic but found little.
Can anyone tell me if the focus screen on the K-X is replacable?
Katz-eye doesn't list one for the K-X.
Thanks.
11-21-2009, 01:47 AM   #2
Should be similar to the K-m
11-21-2009, 01:57 AM   #3
Not surprisingly for a consumer DSLR, the focusing screen is fixed. (It's a Natural-Bright-Matte II screen, incidentally).
11-21-2009, 02:05 AM   #4
QuoteOriginally posted by knoxploration Quote
So interchanging it with a split-screen focus screen - like I did with my K10D - is out of the question, correct?
11-21-2009, 03:26 AM   #5
QuoteOriginally posted by J.Scott Quote
Correct, it's not intended to be user-replaceable.
11-21-2009, 03:56 AM   #6
Maybe it's not meant to be, but it's replacable (it's same as with K-m/K200D). I'd wait for Katzeye with focus point markings.
11-21-2009, 04:45 AM   #7
QuoteOriginally posted by jerrymouse Quote
Really? That's interesting... My apologies for misleading folks, then! Certainly, the user manual makes no mention of the screen being interchangeable. I've not yet had the chance to play with the K-x / K-m in person though (nowhere near me sells either model, that I've found).
11-21-2009, 05:07 AM   #8
I've heard the k20d screens will fit
I'll actually test this theory next week when my KX arrives. (and report back)
11-21-2009, 07:29 AM   #9
QuoteOriginally posted by WerTicus Quote
I don't know exactly about K20D and K-x, but *ist DS, K100D and K10D screens are different.
K100D screen can't be inserted into *ist DS, split screen for K100D is not fixed within *istDS and is misaligned in K10D. I had to cut U-frame from exposured film and put it in K10D mirror box between split screen and prism (leaving original U-frame there also).
Assuming that K-x is constructionally the same as K-m, Katz-eye for K-m should fit it.
And never mix screens between 100% fv pentaprism cameras, non 100% fv pentaprism cameras and pentamirror cameras.
11-21-2009, 10:37 AM   #10
hrmm okay ill wait to see official word from katz
11-21-2009, 10:55 AM   #11
pbo
pbo's Avatar
I've changed my K-x original screen to Nikon K-3 screen, cut by focusingscreen.com for a K-m (K2000), for $90 shipped Express, with rule-of-thirds grid. While not as easy a procedure as with K20D or K10D, it's still doable (there are two "manuals" - one on Katzeye site, one on focusingscreen site, the former imo makes the procedure seem easier than it actually is).
Also, if you add rule-of-thirds grids, focus points will lie roughly at the line intersection points - though a bit closer to the center.
Roughly (very roughly ) like this:
11-21-2009, 12:55 PM   #12
AMBIVALENCE's Avatar
pbo. I always wonder. what is the big circle int he middle for?
and you have to remove the matte original to put the focusing screen on right? How come it seems you still have AF brackets there?
11-21-2009, 02:46 PM   #13
pbo
pbo's Avatar
That's a reference circle for, if I'm not mistaken, Nikon's center-weighted metering area.
And that's not a shot through my viewfinder - I just merged two pictures, one from focusingscreen.com, one from here to show about where the focus points lie w.r.t. grids, circles, etc.
So , ehm, I forgot to erase those focus brackets
11-21-2009, 03:35 PM   #14
Okay - so there is still a glimmer of hope!
I would really like to upgrade from the K10D but in no way can I afford a K-7.
The K-X seemed like a reasonable alternative.
However, I have a lot of MF lenses (Voigtlander's) that I will not give up.
11-21-2009, 06:49 PM   #15
frank's Avatar
K100D/K200D/Km/Kx are all listed as not having interchangeable focusing screens, but I've changed them all (mostly for friends). Yes, Kx has exactly the same screen as the Km and K100D/K200D too. Just make sure you put the original spacer (a U shape thin metal piece) on top of the screen before you fix it in. By the way the screen holder was design (the holder is a simple flat base), you probably can use screens for K10D/K20D as well. But K7 has a different screen, the small extrusion tab is on the left, while the screens for other Pentax dSLR (and probably all film SLR) cameras are all on the right.
So if you want to buy a split screen for Kx, just get one for Km/K2000 or use your existing ones for your K100D/K200D/K10D/K20D
camera, dslr, focus, k-x, photography, screen
K-x focus screen drawing & Travor focus screen issue xjx Pentax DSLR and Camera Articles 2 06-06-2012 10:13 PM
Focus screen help couliseaux Pentax Camera and Field Accessories 2 06-12-2010 11:10 PM
Focus screen chromo Pentax DSLR Discussion 8 03-03-2010 06:12 AM
Quick Question: Pentax KM screen replaceable with split-focus screen? vinzer Film SLRs and Compact Film Cameras 2 01-06-2009 01:21 AM
Focus Screen code4code5 Pentax DSLR Discussion 2 01-20-2008 10:00 AM
All times are GMT -7. The time now is 10:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
