04-06-2010, 12:58 AM   #1
flash does not work pentax k-x
Hi ,
I have just become a proud owner of a Pentax k-x camera with 18-55mm zoom ,its my first Pentax.
the two problems i am facing are as follows:-
1) I can not get the flash to work regardless of which mode i put the camera in.for example if i put the camera in Tv mode set the shutter speed then i open the flash . The moment i pressure the shutter release button ,the shutter does not activate however if i close the flash the shutter activates.
2) When i record video in hd mode on playing there is no sound even though it has been activated from the main menu.Regardless of whether i play the file through the camera or by copying it to a computer.
If anyone can help i will be most grateful .
Ismail rashid
04-06-2010, 05:49 AM   #2
Ira
QuoteOriginally posted by ISMAILRY Quote
Hi ,
Ismail rashid
The flash requires a shutter speed of 180 or less, and the burst is much faster than that.
I have the kx, and I don't know for sure, but the on-board flash might not even operate in Tv mode if you set the shutter speed faster than 180.
04-06-2010, 06:42 AM   #3
i have tried with shutter speed lower then 180 but it still does not work
04-06-2010, 07:36 AM   #4
Ira
Does it work in other modes?
04-06-2010, 07:50 AM   #5
What lens are you using? Try changing the lens to the included kit lens and see if your Flash works after that.
See page 161 in the K-x manual that talks about Flash being unavailable when using certain lenses due to vignetting.
Try following pg 148 to set up sound when making a movie. Also check whether you have increased the playback volume to audible levels as described in pages 148 throuh 151.
All the best.
Krishna
04-06-2010, 10:52 AM   #6
Shouldn't you set it at manual flash instead of auto flash in the settings?
04-07-2010, 01:11 AM   #7
I have tried the other modes as well Av,M and it does not work ,Setting the flash to manual does not make a difference.
The lens i am using is the 18-55 kit lens which comes with the camera.
04-07-2010, 01:31 AM   #8
nulla's Avatar
This might be a silly question but I must ask the obvious
Are you raising the flash by pressing the "up" button
Also what settings have you set for flash.?
Troubleshooting flash is on page 287 of the K-x manual
another thing you could do is reset to default settings and see if that helps.
otherwise it sounds like you have a fault in the camera
Neil
04-09-2010, 09:21 PM   #9
I am having the exact same problem with my new K-X. I have tried all the different modes that SHOULD use the flash. It pops up like it is going to discharge but never does. Same thing happens when the flash is set to manual and I push the flash up button. Any suggestions??? I may just have a faulty camera?
04-11-2010, 08:43 PM   #10
Same thing is happening to me, but I got it working by going into portrait mode with manual flash. Then popped the flash up and it worked! then I changed it to Manual Exposure (1/100 f4.5) without turning it off or shutting the flash and it worked again...
If I turn it off or close the flash lid it won't work again... I'm guessing its a firmware or software error?
Anyways thats what I've found out... can anyone else confirm what I did?
thanks.
update:
its working flawlessly now for some reason... I think a reset helps...
06-17-2010, 10:32 PM   #11
I'm having the same problem. It won't flash at all. No matter what mode I'm in.
I just tried manual flash in portrait but it still didn't work.
06-18-2010, 08:55 AM   #12
Marc Sabatella's Avatar
Is it possible the batteries are too weak to power the flash? have you set the battery type option appropriately? Are the cells freshly charged? Or, if non-rechargeable, they aren't alkalines, are they? Those basically don't work.
06-18-2010, 09:14 AM   #13
they are brand new lithiums :< and i have the battery setting set correctly
in a dark situation, the flash never pops up on it's own
also when i manually pop it up, there's a flash icon in the viewfinder, and when I half press, the icon blinks, but when i take the picture nothing, i thought maybe it wanted me to wait till it's done blinking, so i held it half pressed for like 3 whole minutes and it still kept blinking
06-18-2010, 11:26 AM   #14
Ira
First make sure In Custom Menu 3 that Item 16 is set to 1 (off).
Also, you don't happen to have HDR on, do you? Or another auto bracketing function?
06-18-2010, 12:16 PM   #15
subeeds's Avatar
Sorry to hear you are having problems. I haven't encountered anything like like that with my new K-X. I have the flash turned off on the menu and when I want to use it, I just do it manually by popping it up with the button.
camera, dslr, flash, k-x, mode, pentax, photography, shutter
Why won't Pentax flash PTTL work? jshram Flashes, Lighting, and Studio 61 04-02-2010 08:55 AM
Would an Asahi Pentax flash (AF200s) work with my K200D? causey Flashes, Lighting, and Studio 2 09-14-2009 09:13 AM
Ring Flash Idea would be very cool if it would work on Pentax Peter Zack Flashes, Lighting, and Studio 13 06-25-2008 08:06 AM
Will this flash work on my Pentax K100D? vmax84 Pentax DSLR Discussion 7 03-02-2008 04:47 AM
Will the Miranda 700CD multi dedicated flash work with my Pentax *ist DS? cotterill666 Flashes, Lighting, and Studio 0 11-21-2007 07:24 AM
All times are GMT -7. The time now is 08:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
