07-21-2010, 01:49 PM   #1
builttospill's Avatar
Sticky Shutter Curtain! Any Suggestions?
The shutter curtain on my S3 is sticking. It doesn't stick when it's nice and hot and I've been using it for a while, but it's doing it quite often. When the curtain doesn't close all the way the mirror remains up. I can push gently on the curtain and the mirror will return to it's original position and the curtain and shutter close. Any suggestions on DIY service/repair?
Here's what it's supposed to look like:
and here's what it looks like when it sticks:
07-21-2010, 01:58 PM   #2
Otis Memorial Pentaxian
Shutter service/repair is a fine art and requires a high level of skill. I would suggest sending it to Eric Hendrickson in Tennessee. His prices are fair and his skills are the best. Here is the link:
Pentax Camera Service
The estimates are free and if you opt to not repair, Eric will send the camera back to you at no charge including shipping. What a guy, eh?
07-21-2010, 02:02 PM   #3
Shutter service/repair is a fine art and requires a high level of skill...
I was saving Eric as a last resort. But you make a good point, maybe I should just send it to him so I don't mess anything else up.
07-21-2010, 07:43 PM   #4
QuoteOriginally posted by builttospill Quote
I was saving Eric as a last resort. ...
Scale of charges:
Repairs: $100-00/hour.
Repairs to your DIY repairs: $200-00/hour.
07-21-2010, 08:02 PM   #5
QuoteOriginally posted by Banjo Quote
Scale of charges:
Eric's repairs are about $70-$100 including full CLA and return shipping. So the deal is even sweeter.
07-21-2010, 09:48 PM   #6
Wheatfield's Avatar
Try storing it prism down in a warm place for a while.
07-28-2010, 07:11 AM   #7
I placed the camera in my car with the windows up for the last 2 1/2 days in approximately 100 degree (37 C) weather outside. No luck, unfortunately.
07-29-2010, 06:31 AM   #8
Blue's Avatar
He said a warm place, not an oven. Seriously, that thing probably needs a good cla with the lube being key for your problems.
07-29-2010, 06:32 AM   #9
Blue's Avatar
That may end being on the high side for Eric. Eric is good enough that he doesn't have to gouge. He has incredible institutional knowledge and a million hours of experience on manual focus Pentax gear.
08-01-2010, 03:02 PM   #10
Unless you really want to learn about repairing shutters, and unless you are willing to destroy some cameras in the process, I'd suggest that you just send it to Eric and get it over with. It's something worth learning, but it *will* cost you, time, tools, a camera or two... Or you pay someone and get on with using the camera for the next decade or more.
08-07-2010, 07:37 AM   #11
Yesterday I looked to see if I could pull the top plate of my S2 (which was behaving exactly as you described.) I decided that I would need a real service manual first, so I pulled the bottom plate instead.
Put 3 drops of Ronson LIghter Fluid on the 1st curtain adjuster; all speeds are now to spec and absolutely no trace of slowness in the 1st curtain.
Bob Palmieri
08-09-2010, 09:34 AM   #12
Thanks Bob, that's neat you were able to fix your S2. I had taken the front plates off and lubed the shutter curtain rail, but hadn't done the bottom plate. After removing it now, it was pretty dry. I put a couple drops of oil on the 1st, 2nd and 3rd curtain pinion shafts and snapped the shutter a few times with no problems.
I figured it wasn't quite done yet, so I put it back in the "oven" upside down to let the lube do its thing. I'll put a roll of film through it later today if there's still no sticking.
08-09-2010, 09:54 AM   #13
Blue's Avatar
I hope you guys realize that in the realm of cameras, a drop is a LOT!
08-09-2010, 10:20 AM   #14
Yes, I read in the service manual about how many drops to put at each location. I didn't have a dropper, so I used my small screwdriver tip dipped in the oil to place the lubricant right where it needed to go.
08-11-2010, 08:29 AM   #15
Well it must've worked. The camera is doing great now. Thanks for all your suggestions.
curtain, mirror, shutter
K-x sticky shutter release trigger/button alaricxyz Pentax DSLR Discussion 8 03-31-2010 04:56 AM
ME Super - shutter curtain stuck paolojackson Film SLRs and Compact Film Cameras 4 09-20-2009 01:01 PM
Problem with MV1 shutter curtain ismaelg Film SLRs and Compact Film Cameras 2 04-15-2009 12:10 PM
Max shutter speed halved in rear curtain. Deni Photographic Technique 9 05-12-2008 04:35 AM
Sticky shutter on Honeywell Pentax H1a k6whp Film SLRs and Compact Film Cameras 1 07-19-2007 08:23 AM
All times are GMT -7. The time now is 02:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
