Originally posted by LesDMess Typical size but of course all so much bigger then the M series . . .
Interesting side-by-side shot. The face-on, front view is a little deceptive. I too have a KX (in silver finish) and both my 1000 DTL and my Singlex TLS are larger (the Singlex much less so), particularly in the hand. The 1000 DTL is almost 1.5 cm wider than the KX, several millimeters taller at the pentaprism, about 3 mm taller at the top plate and 6 mm deeper(!!) camera back to mount flange. The Singlex is the heaviest of the three and the KX the lightest. To give credit where credit it due, all three cameras look tiny next to and are lighter than a Topcon Super-D or a Nikon F Photomic.
Put my Super Program back-to-back with the 1000 DTL and it is hard to believe that both bodies use the same film format.
The KX has the same basic dimensions as the Spotmatic and the Spotmatic, IIRC, was the most compact interchangeable lens SLR you could buy prior to the release of the Olympus OM-1. (The Fujica models mentioned above may have been the smallest for a year or so, I don't remember when the various bodies were released.)
P.S. The extra bulk may explain why the shutter sound on the 1000 DTL is so sweet...not as hushed as my Canon-P, but still sweet.
