Don't be fooled by the meter reading!
For all those inclined to measure the trigger voltage, I can only give one bit of advise. Know your meter, and voltage measurement theory!
I say this because not all volt meters are created equal.
Meters have internal resistance, and can load the circuit you are measuring, causing a false reading.
I did a post a long time ago, using my Sunpak Autozoom 3000 flash, and 2 different volt meters.
One volt meter is a relitively new Digital Volt meter with a constant input impedance of 20 Meg Ohms. The other meter was a cheap meter, with a 20K ohm per volt (of full scale) impedance. Changing scales really only changes the resistor in series with the meter movement.
Using the cheap meter, on the 15 volt scale, I measured about 10 Volts, but by moving to the 300 volt scale, I measured 150 volts, and using the digital meter I measured 195 volts.
The meter impedance can lead you to a wrong conclusion. If you are using a cheap meter, start on the highest voltage scale available, since this will present the highest impedance to the flash.
The trigger voltage is measured between the center Large contact of the flash and the side contacts that touch the shoe, with the center button being positive.
