I've so far just initially played around with a K200/2.5 which has such a large front element (77mm) that it is a mass hound (950g - almost a Kilo).
Lens Review Data
As far as the focus peaking itself - does everything it should do. High contrast areas in-focus are outlined brightly. The focus plane moves around the FoV very nicely. I've watched the sharpest focus area move from one edge of a flower petal to the pistil as I rotated the focus ring. I like focus peaking more with each use - I'm not even sure I need a viewfinder any more.
I imagine my use of the lens on the K-01 will be identical to using it on an MESuper since they are quite close in size and mass. I hold the K-01 LCD very close to my face, so the issue with quality output is body motion at my preferred aperture for the lens, f/5.6. I use it primarily for isolating single objects against a blurred background so I frequently have a very shallow focus plane. I've used that lens on a number of film cameras - any problems are user error, not camera or lens.
Works just great with a tripod.
