04-10-2013, 07:27 AM   #1
HELP! K-01 e-dial stopped working
My K-01 is running the latest firmware
Suddenly, while zooming in with the dial (shutter speed & aperture) it stopped
It snaps as usual & no physical difference but settings do not respond anymore
Removing battery & memory card did NOT work
I need serious help as I have 2 shoots tomorrow!
EDIT: I also live in Egypt so not one clue on the possibility of sending it for repair or even where to send it!
04-10-2013, 07:34 AM   #2
This is pretty common with Pentax cameras, and others. Get some contact solution and spray it in the dial. It is not water based and will not hurt the electronics. it will clean off some of the grease on the contacts and allow the clicks to register. I've had it happen with a couple of Pentax cameras and a Samsung NX. It might take a few applications and working the dial until it's fixed.
Edit: This is solution for electrical contacts not contact eye solution, just in case there was some confusion. You should be able to get it from an electronics or a hardware store.
04-10-2013, 07:40 AM   #3
QuoteOriginally posted by kenafein Quote
How do I spary it IN the dial?
There doesn't seem to be quite the clearance, or just spray on top & it'll clean things?
04-10-2013, 07:49 AM - 1 Like   #4
QuoteOriginally posted by dstructor Quote
Spray it into the cracks right around the e-dial. There isn't a lot of clearance; but I sprayed it into a K-7, with weather sealing, and it worked.
04-10-2013, 09:33 AM   #5
pezmaker's Avatar
Personally, and your mileage may vary, and I've never done this with either technique (disclaimers, you know)
I'd use something like a q-tip or cotton swab as an intermediary. Spray onto the q-tip or swab, apply to top of dial with q-tip or swab. I'm probably being overly cautious, but I'd be hesitant to spray directly into the camera body, even through the small gaps around the e-dial.
04-10-2013, 09:50 AM   #6
QuoteOriginally posted by pezmaker Quote
That wouldn't reach the contact. This spray does no harm to electrical components. It's non-conducting. You could actually submerge the whole camera in the stuff, if you really wanted to(Not recommended ).
04-10-2013, 10:03 AM   #7
Would a WD-40 Dry do the trick?
04-10-2013, 10:18 AM   #8
No, don't use that. That will make the problem worse.
04-10-2013, 10:20 AM   #9
An amazon,...etc) link would be great
I didn't find it in the local Radioshack
EDIT: How is this?
http://www.amazon.com/Max-Professional-2053-Contact-Cleaner/dp/B0030MKAV4/re...non-conductive
Safe?
04-10-2013, 10:39 AM   #10
EDIT: How is this?
Max Professional 2053 Mini Contact Cleaner - 4 oz. : Amazon.com : Automotive
Safe?
Yes, that is what you want. Spray it in the cracks and then turn the dial several times in each direction(repeat if necessary). Don't be too overzealous. If you spray too much then your e-dial will not be as smooth, or quiet, when you turn it(not the end of the world if you do, it will still work fine). What you're doing is removing some of the excess grease that they pack around the contact.
04-10-2013, 11:09 AM   #11
Fingers crossed...
Thanks man :|
You have no idea how stressed I am over this
1 year pay...
04-10-2013, 12:08 PM   #12
pezmaker's Avatar
I was thinking more along the lines of not hitting the sensor itself and leaving spots, and a mirror, forgetting of course that there is no mirror in the k-01. Anyway, your advice has more backing than mine - you've done this before, I haven't Carry on!
04-10-2013, 12:47 PM   #13
It does dry without residue. I've never had a problem, but I suppose he could tilt it so it falls away from the sensor.
04-11-2013, 11:01 AM   #14
Hey man, I tried with a local electronic contact solution (dry) but to no avail
I applied about 5 times, rotating the dial both ways for a while each time, still nothing
Maybe a higher quality cleaner?...
'at me bro >.<!
04-11-2013, 11:21 AM   #15
'at me bro >.<!
What do you mean by dry? I suppose it's possible that the dial is just broken, but grease is the more common issue. You can read about it in older threads here, and I've had it happen with 3 separate cameras. Is there anyway you can rent a camera for your shoot? Sorry things didn't work out for you. When I'd do it, if I needed more than 1 application, I could still see progress. The dial turns would register more and more, until finally they registered every time.
k-01, k01, mirrorless, pentax k-01
K-x e-dial not working siva.ss.kumar Pentax DSLR Discussion 3 04-12-2022 11:18 AM
K-01 e-dial not working TaylorRiverGuy Pentax K-01 4 02-10-2013 12:38 PM
problem with e-dial of k-x,please help the noob ultimateamit Troubleshooting and Beginner Help 4 05-07-2011 12:15 PM
K-7:Rear e-dial not working correctly bulacawa Pentax DSLR Discussion 11 05-29-2010 04:13 AM
K10 rear e-dial stopped working ryan s Pentax DSLR Discussion 5 03-10-2008 03:37 PM
All times are GMT -7. The time now is 03:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
