11-12-2010, 07:05 AM   #1
K5 Video recording questions
hi, im interested in this aspect of the camera, video..
i want to know how does it compares to the 7D/5D/D7000, or how is it doing by itself in:
1) Quality (compression, artifacts etc)
2) Rolling Shutter problem... you know the jello effect.. (samples here)
3) FPS, i know it is limited at 25fps, but i want/need 24/30/60 can this be upgraded via firmware?
4) Full manual controls: Does it have them? i dont care about autofocus at all
5) Audio
6) Dinamic range: is it the same as when shooting pictures?
7) Use for special FX: chroma key, etc
this list can be revisited depending on your comments, and they will affect my decision on buying the camera, thanks!
11-12-2010, 06:04 PM   #2
inferno10's Avatar
QuoteOriginally posted by gybp Quote
It's there, as it is in all DSLRs. It seems to be on par with my T2i.
At 720p, you can do 25/30 fps. At 1080p, you can only do 25 fps. We can always hope for the addition of 24 fps later on, but I highly doubt they'll add 60 fps.
No manual control at the moment. It's one of my gripes with video on Pentax DSLRs, and is the reason I have a T2i as well.
5) Audio
Audio seems fine to me. The K-5's sample rate is 32kHz in mono, which is lower compared to the 7D, but is 48 kHz when a stereo mic is used (same as 7D). The K-5, like the 7D and 5D, has a stereo input jack. If you're serious about video, you'll use an external mic on any of these bodies.
I'm no expert at measuring things like this, but I would assume the DR in video is as wide as the JPEG engine allows for. I'll try a test by extracting a frame out of a scene and take a snapshot of the same scene with the camera in JPEG.
Beyond my experience level again. There was a short film done by a group using a K-7 that did use green screen though, so I wouldn't think that the camera couldn't be used for effects like chroma key.
If you want to get an idea of what can be done by a regular person on a K-7 or T2i, check out the Vimeo link in my signature.
- Jason
11-12-2010, 06:15 PM   #3
Banned
The shortcut in manual control aperture, iso and shuttertime works in the K-5 the same as in the K-7. Not as handy as in real manual control, but usable. You can find it in the video-section.
I made a short one in a bar, low light, just under an hour after my purchase of the K-5 (brouht battery from my K-7).
[YT]http://www.youtube.com/watch?v=48YqCBFPvXg[/YT]
11-12-2010, 06:38 PM   #4
"Jello cam" is a fundamental limitation of CMOS sensors. The sensor scans pixels line by line (rolling shutter), so that there may be a noticable difference between the top and bottom parts of the frame. This is present in (virtually) all CMOS sensor cameras including the K-5; just turn on live view and pan quickly to see the effect. The only way to get rid of this effect entirely is to use a sensor technology with a "global shutter" (all pixels are recorded at the same time), such as CCD.
Though it is definitely noticable, I don't particularly find it that bad, as you have to pan fairly quickly before it starts to get annoying. I don't think it's going to be that much of a problem, unless you're shooting fast moving action, in which case you're definitely not using the right camera. It does get substantially worse, though, with longer lenses (for the same reasons as camera shake at higher focal length), so stick with shorter lenses.
Haven't done much experimenting with video yet, so I can't really speak for the quality. Framerate could conceivably be lowered through firmware, but I'm pretty sure they will never make it faster as that would likely require hardware reworking/recertification.
11-13-2010, 04:21 AM   #5
QuoteOriginally posted by RonHendriks1966 Quote
nice!, what lens was that?
camera, dslr, k-5, k-5 ii, k-5 iis, k5, k5 video, pentax k-5, shutter, vs
Too dumb for K-X video recording Finger Video Recording and Processing 19 07-12-2010 10:23 PM
K7 Video maximum recording length dogbear1980 Video Recording and Processing 3 06-29-2010 05:27 AM
kx stops recording video after 30 seconds jupzchris Pentax DSLR Discussion 8 06-20-2010 06:00 AM
how does the lack of AF impact video recording? Keebler Video Recording and Processing 17 02-13-2010 11:44 PM
SD Card for Recording Video on K7 GoremanX Pentax Camera and Field Accessories 4 12-21-2009 09:54 AM
All times are GMT -7. The time now is 03:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
