01-12-2011, 09:05 PM   #1
K-5 strange behavior/firmware bug??
Greetings,
Have had my K-5 about a month now. Pretty familiar with it's operation so far. Was shooting today and set for live view with the internal flash. Camera focusses and gave the beep, press shutter further and...... Nothing, no shutter release. Push flash down, no problem, shutter fires. Flash up without live view, it's all good, shutter and exposure fine.
Tried several modes, green, tv, av, p all same result. Flash up and live view no shutter release.
Anyone can try this and confirm please? I have latest firmware 1.02 installed.
Thanks
01-12-2011, 09:16 PM   #2
Wheatfield's Avatar
Mine works as expected. Push button, LV focus does it's thing, camera takes picture with flash.
What kind of shape is your battery in?
01-12-2011, 09:44 PM   #3
ve2vfd's Avatar
Have you tried a battery pull to "reset" the camera?
I had mine completely freeze a few random times, only a battery pull fixed the problem.
Pat
01-12-2011, 10:21 PM   #4
My LV works the same, flash up or down.
It also locks up half the time when the grip is attached and one battery runs down when the shutter is pressed and instead of switching to the other, as ve2vfd said, it takes dropping all the batteries for the shutter to even close. Bleh!
01-12-2011, 10:28 PM   #5
QuoteOriginally posted by imtheguy Quote
Thanks for checking.
I did some more experimenting and found that if custom function C3-20 'Release while flash is charging' is set to ON, then during live view the shutter fires ok with the flash. But, with the function set to it's default (OFF), where the shutter won't fire until the flash is charged, then my k-5 wont fire, no matter how long I wait for the flash to charge, while in live view with the flash on. Again, without live view the shutter and flash fire just fine with C3-20 set to it's default.
I'm sure the camera should not behave this way. Weather in live view or not, if the function is set to the factory default, the shutter should fire once the flash is charged. It's as if the system doesn't know that the flash is charged in live view.
Could anyone verify this?
01-12-2011, 10:35 PM   #6
Something else is different between our cams then since mine fires sequentially pretty fast in LV and C3-20 set to the default.
01-12-2011, 11:37 PM   #7
Tommot1965's Avatar
QuoteOriginally posted by biphers Quote
Greetings,
Thanks
mines doing the same thing..fully charged battery ...
01-14-2011, 12:01 AM   #8
what sort of battery are you using? generic or Pentax?
01-14-2011, 02:07 AM   #9
Tommot1965's Avatar
Im using Pentax
I had another go at this last night...and sure enough My K5 will not take a image if the flash is "up"
I had to take The OP's advise and tick the box, 'Release while flash is charging' for it too work
Battery is freshly charged...
01-14-2011, 05:17 AM   #10
blende8's Avatar
That's a firmware 1.02 bug.
It worked with 1.01. At least so I have been told.
The problem is only with SDM lenses, I think.
01-14-2011, 08:15 AM   #11
Tommot1965's Avatar
well mines a HSM lens..so the SDM thought works for me ..I dont have a Non HSM lens to test right now
01-14-2011, 10:28 AM   #12
creampuff's Avatar
QuoteOriginally posted by blende8 Quote
Sorry but I think you're wrong on this. I've got 1.02 installed and it works as normal when using LV with flash. No problems with either SDM or screw driven lenses used. And I'm not even using the original Pentax battery.
01-14-2011, 11:35 AM   #13
blende8's Avatar
And you don't have 'Release while flash is charging' checked?
01-14-2011, 07:10 PM   #14
Wheatfield's Avatar
Its turned off on my camera.
01-14-2011, 07:29 PM   #15
Tommot1965's Avatar
thought Id take another look at my K5...Mine was set to AFC...now its back to AFS it works fine in LV with flash...and thats with the 'Release while flash is charging' unchecked..to fire while in AFC..the box needs to be checked..on mine anyway
camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5, release, shutter, view
K-5 strange behavior / bugs? limbonaut Pentax K-5 & K-5 II 3 11-21-2010 10:26 PM
Strange behavior from Tele-Takumar 300mm straightshooter Pentax SLR Lens Discussion 6 06-06-2010 05:56 AM
Matrix metering strange behavior... dlacouture Pentax DSLR Discussion 20 01-22-2009 08:20 AM
Strange *ist ds behavior trd300gt Pentax DSLR Discussion 1 11-14-2008 04:53 AM
K100d built in flash: strange behavior Rafael Pentax DSLR Discussion 5 12-17-2007 03:02 PM
All times are GMT -7. The time now is 12:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
