11-06-2011, 07:53 AM   #1
brosen's Avatar
Problem with the K-5 handling SDXC cards
Please try to recreate this potential problem with the K-5 handling SDXC cards when using RAW+JPEG, as follows:
- Take 5 or 6 shots in RAW+JPEG
- Try to zoom in while viewing the photos in the camera, there shouldn't be any problem
- Now delete 2 or 3 of the images in camera
- Now take 5 or 6 more shots in RAW+JPEG again
- Try to Zoom in while viewing the latest shots in camera
- Now 1 or 2 of the latest shots should be corrupted, cannot zoom in or is corrupted when imported
I did the same test with an SDHC card and the problem did not happen. I think there is a problem with the K-5 handling SDXC cards, or my SDXC cards are defective, but I've tested them in another camera with no problem. I am using Lexar Professional 128GB SDXC cards.
NOTE: Did the exact same test with JPEGs and the problem did not happen, it seems to be related to RAW+JPEG only.
Please could you try to reproduce the problem in your camera if you are using an SDXC card, thanks
Bernard
11-06-2011, 08:26 AM   #2
JohnBee's Avatar
Without knowing how common this is, I'd say it sounds like a firmware update is in order.
Have you contacted Pentax support to inform them of the issue?
11-06-2011, 08:28 AM   #3
aT0Mx's Avatar
And you have at least the 1.02 firmware?
11-06-2011, 08:29 AM   #4
brosen's Avatar
Yes, I've sent them like 3 emails, but it seems they do not get it, they are reluctant to even research it, they just ask me to do dumb things to resolve the problem. Maybe somebody with more influence or contacts with Pentax can help to get their attention ?, thanks
11-06-2011, 08:29 AM   #5
brosen's Avatar
QuoteOriginally posted by aT0Mx Quote
I have FW V1.11
11-06-2011, 03:11 PM   #6
brosen's Avatar
I just did another quick test, took like 50 pictures in JPEG only using the Lexar 128GB SDXC card, deleted 3 of them, and I got "Card Error" messages, it was not possible to view any photo, prior to delete the 3 photos I was able to view each of the 40 pictures without any problem, the only change was to have deleted 3 of them. The only solution was to format the card and loose all the pictures.
11-06-2011, 03:21 PM   #7
bobmaxja's Avatar
If you sent the email over the weekend, I am not sure you will get any answer
11-06-2011, 06:47 PM   #8
In a test case it is always important to eliminate the common denominators.
It is not enough that your SDXC card worked on a different camera. in order to really point it to the camera being the problem, you need to try a different SDXC card - preferably, a different brand and/ or capacity.
11-07-2011, 02:17 AM   #9
Banned
I have no SDXC cards, but this should not be a problem. Not yet a second test from some-one?
11-07-2011, 02:38 AM   #10
QuoteOriginally posted by brosen Quote
You need to add a few more steps to the test procedure for people to follow:
- update your camera to the latest K-5 firmware (v1.11);
- buy a brand-name SDXC from a reputable bricks-and-mortar store (to try and avoid using inferior quality counterfeits);
- format the SDXC card using the K-5 in-camera before using it.
It may also be worth noting that in the past Pentax have generally only recommended and tested certain card brands for compatibility - typically Panasonic, Toshiba and Sandisk (eg for SDHC cards for the K-x )
11-07-2011, 02:50 AM   #11
Chex's Avatar
Lexar is a very well established brand, not one I'd choose, but it's been around a long time. So unless he got a counterfeit from an online store, I'd think it should be ok..
I agree with using your K-5 to format the card.. absolutely!
I would then try loading the card full of Data from your PC to make sure it IS a good card.. you should be able to load 128 GB of RAW/JPG files on it and see them on your K-5.. I think that would be a start in the right direction.
11-09-2011, 08:43 AM   #12
brosen's Avatar
Yesterday I tested two brand new SanDisk Extreme Pro 64GB SDXC cards and I got the exact same error, so clearly there are issues with the K-5 handling the SDXC cards, I've tested 2 Lexar and 2 SanDisk, and all of them are giving problems, I really don't think 4 cards, 2 brand new and 2 different brands are all deffective, I think it's related to the way the K-5 handles the SDXC cards. After that I checked again two SanDisk Extreme Pro 32GB SDHC cards and NO PROBLEM at all. I do not think is Lexar related, as it was previously stated.
I've reported the problem to Pentax US multiple times, I hope they will learn and do soemthing.
11-09-2011, 09:44 AM   #13
The Leica M9 has also had problems with some SD cards (including Sandisk) and finally had to work with the card mfgrs to figure out why some worked and others didn't. They are still testing firmware changes to fix their issue. That is to say that the SD standards aren't as easy to work with as it may seem, and even Sandisk has some unique properties that "generic" drivers may have problems with. This would be especially true with the SDXC cards, as the standard is newer, and all the variations in implementing may not be understood.
So give them a chance to find and sort out the problems, and they'll have a firmware fix. In the meantime be sure to report the issues, giving exact models and specs of cards, and what happened. They can't fix what they don't know about, and testing with all possible models of cards is a nightmare.
For now I stick with SDHC cards, as the standard and variations are more stable (older) and better understood.
11-09-2011, 01:32 PM   #14
Banned
I use those 32 GB Pro cards as well and they don't give problems. Sorry to hear that the new SDXC cards are giving trouble. Can you just use them, without deleting shots? That would save you for now.
11-09-2011, 03:50 PM   #15
How did you test them? Did you format them in camera before use, or using your PC?
I'm curious about this because SDXC and SDHC use (by default) different filesystems. SDHC uses the FAT32 filesystem, SDXC uses the exFAT filesystem. Somehow the K-5 would have to be able to deal with that (in reading and formatting the cards), as would your PC operating system.
camera, card, dslr, jpeg, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shots, test
K-5 and SDXC KeesdH Pentax K-5 & K-5 II 16 11-08-2019 11:34 AM
Problem with the memory cards!! Pepe Guitarra Troubleshooting and Beginner Help 12 10-03-2011 08:48 AM
with SDXC...are you ready for 1TB or more memory cards? Reportage Pentax DSLR Discussion 21 10-08-2010 09:06 AM
K7 video and Memory cards, or how to fix a 720P problem nakey Video Recording and Processing 53 09-28-2009 12:12 PM
SDXC memory cards announced, with a size limit of 2TB Red Pentax Camera and Field Accessories 0 01-12-2009 11:57 AM
All times are GMT -7. The time now is 06:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
