Originally posted by Ayoh The schematic of the sensor module which is shown is confusing as It does not allow for a proper cross sensor layout. However it seems from the text that the image may be the bloggers interpretation of the presenters discussion, and not from one the slides.
It seems the lines are supposed to indicate points on the projecting AF separator lens and not the actual AF line sensors. They should be drawn as circles not lines to avoid confusion.
For reference, this is what I thought the AF sensor looks like:
If interpreted in the manner you mentioned, then their AF sensor diagram seems to be consistent with mine...
Notice that there was another mention of full frame, specifically without an AA filter, on the linked blog post (via Google Translate):
Quote: Here and there, you may wish to ask a lowpass-less full size. And there was a Otasshi may announce from the upper, from "being considered" and "We are positively considering" seems to say it one step closer to the full size Release (^ ^ v
Norton Internet Security's Safe Web feature indicated that the site is safe. I did not get a "Caution" or "Warning".
--DragonLord
