Originally posted by FHPhotographer I recently returned a K-x/18-55 to B&H because although I liked everything about the camera, I couldn't see the data line in the VF when out in bright sunlight. Since the data line is transmissive and not reflective, lens and aperture changes didn't help.
I have not the slightest clue what you are trying to say with "transmissive and not reflective". Viewfinder info is based on LED system which is placed outside the image frame on a black background. LED stands for
light emitting diode. Nothing transmissive here. And what would be reflective?!? :ugh:
The camera even adopts to the scene contrast. That means in bright scenes the viewfider info LED will glow more bright. If the scene contrast is low and image is dark the VF LED will dimm down and light a bit lower. This is not something K-x or K-r specific, it is standard across the brands.
Lens change has no effect on this, because the VF system is fixed inside the camera. Changing aperture and expecting this will have an effect on how the viewfinder info will be displayed is just plain stupid. Sorry.
Quote: However, I'm now member of the Forum that the K-r is better. Anybody have experience with both the K-x and K-r to confirm this? Nobody in town has both in stock, so I can't do a comparison myself. Thanks for any input,
Brian
I have both and the VF LED system is exactly the same in them. Still don't understand what was your problem. You couldn't see the info because it was to dim or you coudn't see it because the info was too small? Are you wearing glasses? I do wear them and have no problem with the VF info display.
cheers,
d
