Show Printable Version 4 Likes Search this Thread
3 Likes  #1
WR and AW lenses: a difference you may not even know existed
Posted By: bwDraco, 07-14-2012, 11:55 AM
TL;DR: Both WR and AW indicate weather resistance, but AW indicates a higher level of environmental sealing than WR.
What is the difference between WR and AW?
  • What is the difference between DA WR and DA* lenses in terms of weather sealing?
  • Why are the D FA 645 55mm and DA 645 25mm lenses designated as AW?
WR and AW both designate weather-sealed lenses. Non-star lenses that are designated WR use a "simplified weather-resistant construction" to protect against ingress of water. DA* lenses, although not indicated as such in the lens name, are considered AW (newer boxes for DA* lenses are often marked as such) and are "dust-proof and water-resistant because each part is individually sealed" (page 7 of the DA lens manual), offering a higher level of protection against environmental conditions than the WR designation indicates. The above 645 lenses are marketed as fully sealed against dust and water, at the same level as DA* lenses.
--DragonLord
07-14-2012, 12:12 PM   #2
LeDave's Avatar
Great to know! Thanks DragonLord.
02-27-2013, 10:49 AM   #3
Thanks
Thanks for the info
07-17-2013, 01:29 PM   #4
I recently purchased a K-30. The camera itself is consider WR.
If I placed a non-WR/AW lens on the body, will the body still be fully weather sealed?
07-17-2013, 01:38 PM - 1 Like   #5
QuoteOriginally posted by oxnard111 Quote
No, you need a weather sealed lens too, as it's got a washer that goes around the lens mount.
da, da*, lens, lenses, level, water, weather, wr
Difference between SMC A and LS lenses???? LightMeter Pentax Medium Format 13 01-09-2012 09:22 AM
Difference between two Sigma Lenses? reivax Pentax SLR Lens Discussion 13 06-28-2011 08:14 PM
difference between pentax 18-55mm lenses? dwhopson Pentax SLR Lens Discussion 2 04-04-2011 09:34 PM
What is the difference between these two 55-300mm lenses? RUSBoris Pentax DSLR Discussion 6 10-11-2010 07:49 PM
Pentax K2 model that never existed? Gregt Film SLRs and Compact Film Cameras 11 02-17-2008 10:31 AM
All times are GMT -7. The time now is 11:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
