Originally posted by bossa If you remove the sensor size and use the LW/mm I believe you get a figure which allows an easier comparison across formats as long as you have an idea of the pixel density.
However, this assumes that one always print/view images with a size proportional to the sensor size.
Your "same resolution" argument is valid if you print the image from the sensor that is twice as large, double the size of the other image.
In practice, that is not a reasonable assumption. While larger sensors enable larger output sizes, typically people use the same output sizes, regardless of sensor format (in which case the lines/picture-height metric is the relevant one).
Pixel peeping at 1:1 resolution has its place but I believe it is the wrong approach to evaluate (practical) resolution differences.
