Originally posted by RiceHigh I prefer the former!
What cons do we have than there is no offer and the lack of functions? Remember "least is better than none"! (Bugs would be another concern)
That's just the thing, JCPentax in one of the other threads stated that it was removed as a feature because its implementation actually caused problems with the video. Keep in mind, contrast-detect autofocus takes a lot of processing power, and running that side-by-side with the actual video recording when using such a low-compression format may be the problem here. Sure, the t1i might be able to use CDAF in video, but last I knew it also uses a format for video with a lot more compression.
Besides that, really, the main reason to use a DSLR for video is shallow dof. Shallow dof is not a good thing to mix with autofocus in video. If you want a video device to focus for you, a camcorder is a far better choice.
