Originally posted by Shingoshi The Kodak SLR/n is a Full-Frame camera with a cost far below that of anything else that provides that feature. I've seen a number of SLR/n available with relatively low duty-cycles. And as for maintenance, it's still available. So for those for whom such a decision makes no sense, I hope you die with your curiosity.
Wow... Not sure how that last comment was intended, but it really didn't sound friendly. Note that I didn't say the decision made no sense, just that I was curious of your reasoning given the SLR/N's potential drawbacks. (The main one being that, compared to modern cameras, it is very, VERY noisy at anything beyond base ISO without significant processing). I've used it myself, albeit many years ago now. To quote Luminous Landscape (with a few bits emphasised by me):
It's interesting to first note how saturation dramatically decreased from ISO 160 to 250 and how the image loses contrast as the ISO increases. Noise has increased only slightly between these speeds. At ISO 400 the noise is somewhat worse, but blotchyness really starts to rear its ugly head. By ISO 800 the image becomes so noisy and blotchy as to be almost unusable. It's also worth noting how apparent resolution decreases as ISO increases.
This is a 100% sample at ISO 800:
(Courtesy Luminous Landscape, mini-review here:
Kodak DCS Pro/n)
Believe it or not, I'm honestly trying to help. You're right that the SLR/n is among the cheapest full-frame DSLRs available (along with the 14N, SLR/c, and Contax's N Digital) - but they're cheap for a reason, that being that they're second-hand cameras with not only the potential issues of any second-hand, unwarranted product, but also huge drawbacks compared to modern cameras with modern technology.
The SLR/n just struck me as a curious choice, because in other posts you've espoused the benefits of full-frame in terms of resolution and print size, and another common reason for desiring FF is lower noise / better sensitivity. With the SLR/n, you'll get none of those advantages, and arguably you'll get significantly worse performance than you'd get from a modern APS-C DSLR in *most* areas. The one point where the SLR/n will significantly beat modern APS-C DSLRs is in wide-angle capability, and it would appear that's what's most important to you.
Were it me in your shoes though, I'd probably live with APS-C in the meantime while I save up and get the cheapest of the current FF DSLRs (Sony A850, fairly easily available now for around $1,800), or whatever model was current at the time I'd saved up. Perhaps you're aware of the potential drawbacks and find they outweigh the disadvantages of APS-C and the expense of a modern camera though. If so, that's great.
