25.4mm f1.5 C mount 16mm film lens, taken of an old bolex that had seen better days.
Lens has been dropped at least once (big dent in the filter ring) so the wide open behavior may be atypical of this lens. But I doubt it
f4? Depth of field was about a foot and a half at most.
The bokeh is pretty smooth at f8 and the scale focus is pretty much dead on.
f1.5, wide open. The depth of field is a few millimeters at best and everything is bloomed out. I wouldn't shoot at anything below f2.8, highlights and edges get blown. Unless you like the look...
All shots 12M jpg, 3star, IR filter, +1 sepia, -2 high key, +4 contrast, +2 fine sharpness, ISO 640. All images were taken at f8 unless noted. No shim seems to be needed for infinity focus.
1more lens from the old bolex, but it's a 90mm, so I don't know when I'll get to try it out.
