05-06-2010, 01:42 PM   #1
FA 31mm limited focus ring is loose?
Hi,
I just purchased a used FA 31mm limited lens from the marketplace here and I noticed that the focusing collar when I rotate back and forth, it is quite loose. Is this normal for the FA31?? I also notice that it slightly sticks near infinity.
Do I have a "bad" copy of the lens?
Steven
05-06-2010, 02:10 PM   #2
Other than that, I took a few pictures with the lens on my K7 and they are tack sharp...
05-06-2010, 03:51 PM   #3
No it is not suppose to be loose, but if it doesnt effect your images then I guess dont worry unless your a perfectionist and can exchange it.
05-06-2010, 05:10 PM   #4
pcarfan's Avatar
What do you mean by loose ?, if it is wobbly then it is defective. If you mean it is easy to rotate, then that is somewhat difficult to quantify. I can rotate it with just one finger, so don't have to grasp it. It is the same with the FA43 and the FA77 is a little tighter. Hope this helps.
05-06-2010, 05:18 PM   #5
QuoteOriginally posted by pcarfan Quote
Lets see loose to me means the focus collar is very easy to rotate and also as I rotate the collar one back and forth the drag is not consistent and seems to loosen as I rotate towards infinity.
No I am not a perfectionist but for a lens that costs more than $900.00 I was expecting a little more, but I have no other FA limited lenses to compare it with.
Steven
05-06-2010, 06:47 PM   #6
pcarfan's Avatar
The drag is consistent with mine, and I think it should be.
05-06-2010, 06:54 PM   #7
scorpioh's Avatar
Mine is consistent too.
05-06-2010, 07:03 PM   #8
Thanks pcarfan and scorpioh that's what I though also. I think mine needs to be checked.
Steven
05-06-2010, 07:31 PM   #9
Have you contacted the seller?
NONE of my FA (and DA) lenses have (had) heavily or even moderately damped focus rings including the FA LTD lenses. If the M42, K, M, or A lenses did, Then I would be concerned.
05-06-2010, 08:03 PM   #10
henryjing's Avatar
You should define the loose clearly, and I think I can define the condition consistent too.
05-07-2010, 03:10 PM   #11
I did some more testing today with my FA 31mm limited lens using live view and manual focus,
there seems to be to much "wiggle" in the collar, when I get confirmed focus the collar to easily slips so it's hard to "lock" the focus.
Steven
05-07-2010, 03:21 PM   #12
henryjing's Avatar
QuoteOriginally posted by kuau Quote
Steven
I have used this lens with my ME super edition, and I have never experienced what like you said.
05-07-2010, 03:24 PM   #13
henryjing's Avatar
Check this.
I seldom used this lens on my K-7 or K-x, because of the "1.5" factor on the APS-C.
I took several pics with 31 on my ME, no problem at all.
05-07-2010, 03:26 PM   #14
henryjing's Avatar
Also check this.
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/96314-little-shake-fa-31-a.html
here is a thread I post the day I got this lens from B&H, you can check the date.
05-07-2010, 03:56 PM   #15
KjetilH's Avatar
My DA40 shows some of the same tendencies, especially being a bit "sticky" when rotating the focus ring. It was dropped into the ground by the previous owner, I understood it as it was in the pouch, and it is not possible to notice any damage.
Judging from this "behaviour", it may have been rough handled. It does not affect IQ or AF though, I suppose the focus mechanism took the blow.
I would suggest examining the lens, both exterior and if the lens tube is wobbly. My lens has some quick-shift problems, but it was cheap enough that I don't really care. Don't conclude too quick though, consider this a suggestion backed up by one single case.
31mm, fa, fa 31mm, k-mount, lens, pentax lens, slr lens
SMC Pentax-M f1.4 50mm loose front ring? theperception2008 Pentax SLR Lens Discussion 6 05-04-2011 08:06 PM
Tamron 17-50mm/2.8 Loose Filter Ring? Venturi Pentax SLR Lens Discussion 4 06-18-2010 06:57 AM
DA L 18-55mm manual focus ring too loose jamesv93 Pentax SLR Lens Discussion 2 11-28-2009 12:03 AM
How much focus would I loose mounting a m39 on my pentax? melander Pentax SLR Lens Discussion 5 02-09-2009 05:57 PM
31mm Limited benjikan Pentax SLR Lens Discussion 19 04-09-2007 09:22 PM
All times are GMT -7. The time now is 08:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
