Originally posted by creampuff As we all know Pentax has done away with using a metal lens mount and using polycarbonate plastic for a number of el-cheapo consumer grade lenses as a means of saving money. Some of the cheap FA, FAJ and now DAL zoom lenses all use plastic lens mounts.
Just wondering if anybody has substituted the plastic mount with a metal one cannibalized from a dead lens? Is it even possible to retro-fit given that the pins don't look the same? I've got one el-cheapo Pentax zoom but after seeing plenty of Canon and Nikon kit lenses with broken or sheared off plastic lens mounts, I'm toying with the idea to replace the plastic mount with a metal one on my lens to make it more durable.
Good idea or not? Any thoughts?
Good idea? Hmmmm...If you have a junk donor lens
AND the recipient lens you have is out of warranty
AND you have access to and are handy with lens repair tools...Sure, go ahead and attempt the upgrade, document the process, and post the results here. Better yet, figure out how to do it, have somebody design/make an aftermarket upgrade/replacement K-mount kit and offer it on eBay for $30 BIN. You might even be able to follow up with Nikon and Canon versions and get rich!
OTOH...What is the real world probability of an accident damaging the mount without damaging the rest of the lens? The way I see it, the main advantage of metal over plastic is durability over time. Abrasion will have its way with plastic parts long before the same happens to stainless steel. Remember too, that the cheaper mount on the DA L lenses is the part we can see. I would suggest that the lens has many more internal parts that are lighter and less robust than the non-L version that will likely fail before the mount.
Solution for new K-x and K-m (K2000) buyers? Don't buy the two lens kit. Negotiate with the dealer for an upgrade to the non-L version of the 18-55 at time of purchase. That failing, use your DA L lens until you break it or it wears out and then replace it with something better.
