It had been bugging me that I couldn't get the purple fringing comparison to work right - for whatever reason, every time I took a screen shot of the window comparing the images, the sky turned purple. And if I tried generating crops, the fringing was reduced across the board (ACDSee's demosaicing algorithm apparently results in less fringing than the camera's). While I could have tried regenerating the crops in the Pentax software, I've opted for a different solution. I've taken the comparison screen shot - purple sky and all - and processed it to take the exposure up one stop. That washes out the sky enough to not be as much of a distraction, and it really brings out the fringing, too. So I've again updated my previous post to include that image.
I thought it important because aside from bokeh (which I find subjective), this was really the only aspect of the comparison that couldn't have been predicted and indeed seen as all but inevitable just from thinking about the difference in focal lengths.
Bottom line, I'd characterize the three lenses as follows:
- The 100 is the sharpest when comparing images at constant magnification (by a small margin over the 120 and a larger margin over the 135). And not that the others are particularly large or heavy (they aren't!), but the 100 is *noticeably* smaller and lighter. However, it has the most purple fringing by far, it lacks a built in the hood, and it can't blur a background to the same extent as the other two. It is the most generally useful portrait focal length of the three, but it has the least "reach". It is not too hard to find with a little patience, and it usually goes for $100-$150.
- The 135 is the slowest of the three by a half stop (or a little more), but it can resolve the most detail in distant objects (by a small margin over the 120 and a larger margin over the 100). Thus, it's the pretty clear choice for most outdoor shooting, where you want the reach and where being half a stop slower isn't as much of an issue. Indoors, its length and slower speed make it not as good a choice as the others most of the time. Although in large and reasonably well lit spaces, I have found that it can and does shine. This lens is easily found any day of the week for under $100.
- The 120 is exactly the compromise between the other two I hoped it would be. More "reach" than the 100 (and with a built in hood); faster, wider, and sharper than the 135 when used indoors at closer range. The fact that it also has the least purple fringing and, for me, perhaps the nicest bokeh, is a bonus, although it does prove to be marginally slower than the 100 (less than a quarter stop). If you're looking for a good general purpose medium telephoto lens for both indoor and outdoor use and fear a 100 would be too short too often and a 135 would be too long too often, the 120 is your lens. Unfortunately, it is much harder to come by than the others. It usually sells for $150-$200, but you may have to wait a while for the chance to buy one.
