I've got a solution to the "wild imbalance" of this lens (just got my Really Right Stuff package today).
I used an L84 lens plate (3.6" long, no-twist flange), two B2-Pro/L clamps (drill out the threads of the two 1/4" X 20 screw holes in one clamp, then mount them back to back with two 1/4" X 20 X 3/4" screws), and an 18" camera support bar. The back to back clamps mount to the lens plate and the support bar, and the support bar gets clamped onto your tripod head (a Wimberley Gimbal head is ideal). With this setup, you can use the generous length of the support bar to get the lens/camera combination into fingertip balance on a Gimbal head, which will make it a joy to use. The space resulting from the back to back clamps gives you good room for your hand to operate the zoom/focusing ring as well. The stuff is pricey, but without it the lens would be unpleasant to use and would probably end up collecting dust, which would be a sin. Of course, if you're a metal fabricator, you can probably custom build something.
