Originally posted by gazonk I hope you get a better copy. I got my DA55-300 for christmas, and haven't seen any signs of decentering or other weaknesses so far - the lens is excellent. If I really pixel peep high contrast shots @300mm, I see a little CA at the borders - that's the only weakness I've seen so far.
Well, it is on its way back to Amazon. Will I be replacing it with another copy ? Probably not.
Having had them both (50-200 and 55-300) side by side for a weekend's play, I wasn't that impressed. Admittedly, I might have had a dodgy copy of the 55-300, but I just did not like the size, weight, stiff zoom, twitchy focus ring, lack of WR, etc., compared to the 50-200.
By the time you'd put the lens hood on the 55-300 is about a foot long and about twice the weight of the 50-200. I tried to convince myself that this was worth it, given the extra reach, slightly wider aperture and rumoured better IQ. I took some test shots of newsprint
Sharpness Test PENTAX-DA 55-300mm F4-5.8 ED (and
Sharpness Test SMC Pentax DA 50-200mm f4-5.6 ED WR) to see how sharp it actually was. There did not seem to be much in it. Not enough to convince me that this was a 'must have' lens.
Also, if I really needed 300mm then I could use my cheap
Super Paragon 300mm f5.6 mirror (285g, only
65mm length) and live with the doughnuts. Or, if I was feeling fit, take out the weighty £10 eBay
Miranda 75-300mm f4.5-5.6.
