Originally posted by epqwerty I could have sworn that one of e forum members did an indepth review of all the 35mm and found that the daL 35 was slightly worse then the fa in terms of image quality. But only slightly
If there is one thing I have learned, it is that even
slight changes in your test setup will mess up your results. Also I found that sharpness, contrast, and color all influence my perception of what is "better". Of course "what is better" will also depend on whether you check corners, sides, or center. And even a comprehensive test often seems to end up focusing on a particular lens "weakness". This is of course before we even talk about variation on the lenses themselves.
So what
I did can hardly be refererred to as a "test", but rather a quick "test-like" evalaution (tripod, locked-up mirror) etc. It is based on this quick evaluation I believe the two lenses are virtually the same in IQ. I also mentioned that I
thought the FA might be slight better, but any difference was so small it might just be focus, shake, etc. Any difference in IQ
IN MY OPINION would be so small I would not choose the FA over the DA. Hence my statement that DA owners are not giving up IQ.
To put it different: The difference in IQ betwen a Tamron 70-200/2.8 and a DA 55-300mm even at F/8 is VERY NOTICIABLE, despite the relative cost difference (2X) is about the same.
Having said all this the main point of my post, was really that there is a "full" half stop difference betweent the two.
