Hi all, I am considering getting an adapter K to 67 lens to use my P67 Macro 4/135 on my K7 body. Does anyone have some sample shots of this combination to post? It could be very nice to see some in advance and compare to my other close-up/macro lenses. With my SMC K 2.5/135 I am limited by the minimum focus distance at 1.5 M. and with my SMC M Macro 4/50 at 0.234 M. I often come to close to the subject.
So the 67 Macro 4/135s minimum focus distance at 0.75 could be just right. Thank you, regards Jakob Trägårdh, Copenhagen
SMC K 2.5/135
SMC M Macro 4/50
I think the stats look like it could be an interesting and cheap (since I already own the lens) combination for macro/close-up work:
Pentax SMC 4/135 Macro (1989) w/ Adapter K to 6X7 Lens
APS-C
Crop Factor: 205,2 mm.
Diagonal FoV: 12.2 deg,
Horizontal FoV: 10.2 deg.
Magnification: X 0.32
Minimum Focus: 0.75 M.
Minimum Aperture: f:32
Diaphragm: Manual/Automatic switch, 8 blades
Weight: 620 g.
Diam x length: 91.5 x 95 mm.
Filter Size: 67 mm.
Optical Construction: 5 elements in 3 groups
The adapter cost about 60 US and ads about 3-4 cm to the length and 190 g. to the rig.
