Last week I ordered a new Sigma 8-16 because I was granted special access to photograph a national monument after hours (sunrise and sunset), and I needed the UWA lens to get the shots angles I wanted. Plus, it was a lens I had been thinking about for a while. This was the opportunity that pushed me over the edge to place the order - even though I really did not need yet another wider UWA lens - this was special, in that I really need a rectilinear 8mm.
Came home from work this evening and the box was on the counter. Unpacked it, mounted it and went out and shot a few images, as I was loosing the light. Came back in and took a look at the photos. The fire hydrant across the street 75 feet away was not sharp. An Ocotillo 3 feet away was not sharp - all using auto focus. This is what I was afraid of. New lens and ...... I have never had to send a new lens back. Actually, I have never returned a lens.
I had commented on a similar thread a while back...
... same problem. The lens autofocuses well beyond infinity. In the other thread a -10 correction fixed it to some degree. But, I have 2 weeks from today, and the lens should have been spot on - and its not. I'll try a 10 correction factor tomorrow morning to see what it does, but quite frankly, this is not right.
Well, I sorta of factored in some "just in case time" on this, but not expecting to use it. So, I'll call B&H for a RMA number and see if they will do an immediate swap with out waiting for the return to arrive. Hopefully, #2 will be better.
Here is one of the shots, along with a 100% crop - straight out of the camera.....
So, I went back and re-read what I wrote (my analysis), along with the rest of the thread. Given the extreme field of view and everything, should I really expect sharper at this UWA focal length? Am I expecting way too much? I also read / looked again at the Sigma 8-16 club thread and images. Considering what I see in the other threads, I am thinking that the lens should be sharper that what I am observing (given a pretty small sample window and lighting conditions). I am trying to be objective here.
I also have the 10-17, and 12-24. I went back into my archives and took a look at some images and compared it to some common locations - at sundown, I scurried over to an overlook that I sort of use as a photo lab. I am seeing sharper on my 12-24 @ 12. But I did not shoot a 12/12 comparison.
I did shoot a number of shots at 16, both AF and manual. The 16 does look sharper, and the AF is much better at 16 than at 8.
So, I'll give it a quick try tomorrow before going off to work - and make a final decision then.
