YES!! I made, it was allmost easy job! Now it works like a dream!
Originally posted by jatrax If you want a hobby project, sure go ahead. But do not get hopes too high. And if it works you can come back and say "I told you, ha ha".
I don't say anything...
Originally posted by glasbak Never opened this lens, but I suspect it will be similar to other lenses.
If it is only the tube behind the focus/zoom ring that is damaged, then just remove it, it has only a cosmetic function,
It will be fixed with three screws, when these are loosened,you can shift the tube up (if the dents allow it),
You will find new screws, which hold the rest of the front tube, and are also responsible for the adjustment of the constant focus during zoom action.
When the front section is removed, you can separate the dented tube from the rest, and try to 'fix' it.
It was just "cosmetic" piece.
First I took bayonet away, found some new screws to open etc. finally I could remove that tube with dent, and I managed to reshape it.
Originally posted by reeftool I don't think a body shop dent puller would be a realistic approach. It involves either drilling a hole, inserting a screw and pulling it out or spot welding a stud and pulling, both of which could damage internal parts. The lens still will need to be disassembled. A possible solution suggested by my evil twin, Joe the Cobber, is to cut the dented section out with a Dremel tool and wrap the barrel in duct tape.
I'm glad that I managed to solve my problem without dremel
I took some photos of process, if someone NEED those pictures I can mail those.
LeGu
