Originally posted by axl Hi guys,
so my money has fianly arrived, and I decided to get rid of my Tamron 28-200 and replace it with different walk around lens. I discarded option of Tamron 28-75 f2.8. Every member that has ever held or shot this lens is recommending it but 28 is too narrow for me for everyday use. Plus it would leave me with 8mm gap between my Sigma 10-20 and new lens.
I discarded primes as well. For one reason or another.
So my last two choices are:
Sigma 24-70 f2.8:
+ built quality, contrast/colours, f2.8 throughout the range
- size, weight, filter thread size (82mm)
Sigma 17-70 f2.8-4.5
+ ??? smaller filter thread, smaller and lighter, 40GBP cheaper
- 4.5 at 70mm ???
(don't know that much about this one)
What's your opinion guys, I will buy one of these two for sure, but can't decide which one. It would accompany my 10-20 as main lens. Can anybody recommend ane of those two?
There's poll too, so if you're not bothered to write, at least take a vote please.
Many thanx
Peter
Peter
I went through this process before christmas, as I began looking for a similar lens.
My initial thinking was either the sigma 24-60 or sigma 24-70, thinking that a 4 mm gap would not be too bad.
I ended up with the tamron 28-75, and decided that I would 'bridge the gap' so to speak, with the origonal kit lens from my *istD, the FA-J 18-35
The ultimate decider for me, and this is really a personal decision, was filters. I already had a polarizer and two different graduated ND filters for the 18-35 and with the filter diameter of 67mm, the tamron used the same filters. savings of several hundred in the process.
I was leaning heavily to the sigma 24-60 becaus eof the same 77mm filtyer as the 10-20, BUT for polarizers, the field of view makes for un even lighting anyway, hence not much use on the 10-20.
In the end, I chose 3 lenses as the solution, with overlap of the three. THis may prove out to be the best of all, because I have 2 lenses for the 18-20mm range, and two lenses from 28-35mm, and as a result should not get caught changing or an extra mm
edit note; except for my 10-20, all my lenses by decision are full frame, this is because I still shoot film with my PZ-1 from time to time, and all my lenses, inclusing the FA-J 18-35 are fully functional on the PZ-1. That excludes some of the lenses you are looking at
