I recently acquired a lens that has become a bit of mystery to me. The lens has no brand markings on it - the only text there says :
AUTO TELE-
1:2.8 f = 135mm
And on the bottom there is a tiny text engraved saying :
LENS MADE IN JAPAN
The lens is in M42 mount with switch marked A M, for either auto and manual aperture control.
Having some other nice 135mm lenses I wouldn't bother at all - if only this one hasn't been this darn good !
It has beaten hand down my Tokina 135mm 2.8 - as Tokina used to have a little bit of softness at 2.8 - this one here is just sharp ! Also some other lenses I had - mostly strange branded and also SMC M 135 has failed to compete against this unknown and unbranded lens. The colors are great and the bokeh is fantastic ! Furthermore - it focuses down to 1.35m and has awesome build quality - but still is very light at the same time , 360g. Additionally it has got some sort of coatings - both front and the back are having strong bluish tint - especially rear element, plus the lens has good resistance to flare as shots against the sun still were good with only slight loss in contrast.
So all in all - quite a sleeper if you ask me - and I got it in nearly immaculate condition!
I just need to solve this mystery - what lens is that, can someone point me into any direction ?
Below are photos of the lens , and then samples taken with my K10D.
Below are samples taken with my K10D - all @ 2.8 - shoot as JPG in camera and resized in irfanview (
right click on each sample and select show image - or similar option - so you can review the image in full resolution - which is about 1800+ pix wide ).
Last shot was either shoot @2.8 or @4 - not sure as I forgot to note and exif doesn't contain aperture in this case - but a hint is there in that I shoot it at ISO 100 and 1/1250s. - quite fast and there was a lot of clouds - so quite possible that I shoot it also at 2.8 !!
Reason: added links to imaged and thumbnails
