To be honest, i've stopped posting in the Post Your Photos gallery, nobody comments on my photos and that is really depressing. The lens forum is like my favourite forum here as most of you have probably noticed and so i'm going to tie in any of my photo posts with lenses.
I attended
Scotiabank BUSKERFEST 2008 - August 21st to 24th ::: In support of EPILEPSY Toronto today and managed to catch a few shows: Flam Chen, Space Cowboy, Dream State Circus, Rob Williams, Pogo Dudes. It was a great show and lots of events, very busy. There are also night shows, but I couldn't stay out that late.
Some lessons learned this time around
-Fast Primes are great for action
Stopping down these primes to 2.8, I was able to get ample shutter speed at ISO 400. Also great bokeh on the action shots. with the 77mm, at a relatively far distance, gives enough useful depth of field. When i had the FA31 on for wider shots, there's plenty of DOF at 2.8 for this style of photography which is the usual fear against using the fast lenses at large apertures.
-But event photos should be taken with zooms
standing in a dense crowd, if the subject moves back and forwards, prime doesn't really cut it. There were a lot of photos where i had to cut off important parts of the scene because i couldn't move and was stuck with a prime. unless i have another body ... hrmmmmm
there goes her foot
the dude's actually on a unicycle!
-pf not really a big issue with the FA77
the FA77 is supposed to have bad PF, but i haven't really noticed it too much, except if i go 100%
a bit on the white belt on the hat, can you see it?
-AF-C tracking is a bitch, results were surprisingly decent
although the constant adjustments were disconcerting, coming back home and checking the results, there were no significant problems with the FA77 tracking, however the FA31 seemed to focus inconsistently at times. good thing my K100D can adjust Focus
-when it's impossible to have the camera follow the action, MF
Pre-set by focusing on something in the same distance prior; of course this isn't perfect, but did get quite a few keeprs and some close photos. this was the great part about the FA Limiteds, great MF feel, especially the FA77. however the FA31 has a very short throw from 2m to Infinity that kind of made it tricky
-missed my FA43, should have brought it out. the FA31 was too wide for most of this stuff
Other Comments
-shooting action events
center weighted metering, AF-C Single Point or Auto Point OR MF, Av mode with fast shutter, continuous shooting
-went from the "Bright" to "Natural" tone curve... photos look a lot better, the colours not as P&S vibrant
-Brought a Nikon P&S as Backup for wide angle shots, totally garbage for this event
EVF is nowhere fast enough and Contrast Detect AF was slow. My brother had a Pana TZ4 and had the same problems. "Sports" Scene Mode can only help so far. It's OVF or nothin' baby.
-trust the meter / check the histogram
in the bright sunlight it's easy to look at the display and see dark figures and assume the photos were underexposed or the lighting was too harsh. totally not the case for most of my photos. there were some photos i thought were dark and put positive compensation but found it it wasn't actually required
-i want another body! and a grip
shooting too many portrait orientation hurt my wrist
-need to look more seriously into the DA* 50-135 if i attend more of these events ... would go well with a K20D and Grip
-see the rest of the photos at the bottom link
thanks
