This is a question of what range of lenses in total you want in your bag.
my own opinion is that if you practice a wide variety of photography, from archatecture to landscape to portraits to wild life you need ultimately to cover from about 10/12mm at the wide end towards 400mm at the long end.
the question then becomes how do you want to fill this range.
For general shooting I do it with 4 lenses (Known as Lowell's Lens List or LLA
Sigma 10-20mm
Pentax 18-35mm FA-J
Tamron 28-75mm F2.8
Sigma 70-200 F2.8 plus 1.4x and 2x TCs
this gives the range in noted above.
If you don't need wildlife and speccifically long telephoto, perhaps the 50-135 is OK for you. This could change your package to be either the sigma 10-20 or pentax 12-24, then a 16-50 F2.8 then the 50-135 (or sigma 50-150) as a 3 lens kit.
You could also decide that there is not much use between 135 and either 300 or 400 and simply get a long prime as opposed to a zoom or teleconverters.
If you are thinking between the 70-200 or 50-135 it is time to map out your entire system
