I'll keep this short. We should move this somewhere else, if someone feels it is worth continuing.
Originally posted by audiobomber Lots of lenses reach optimal sharpness at F5.6. The FA 50mm reaches maxiimum center sharpness at F4.
The FA 50/1.4 is a very sharp lens. Most consumer lenses do not peak below f/8. Certainly most 70-210 lenses will be a lot less sharp than the FA 50/1.4.
Originally posted by audiobomber So you would say a K10D, with the same sensor and higher pixel density, produces better images than a K100D at high ISO. That's a controversial statement, isn't it?
I wouldn't say that. There are a lot more differences (sensor, firmware) between these two cameras than just pixel density.
Originally posted by audiobomber The linked article below is pretty dense reading
Nice article. Thanks!
Originally posted by audiobomber the conclusion at the end is simple enough. More pixels produce higher noise at higher ISO and larger sensors with more pixels produce higher quality images at low ISO.
That's not the message of the article. The article directly supports what I've written:
Quote: Rather than having strong dependence on the pixel size, the noise performance instead depends quite strongly on sensor size
In other words, the biggest factor (primary effect) is sensor size.
While it is true that big pixels (currently, this is technology dependent) have an advantage in high ISO applications, this is a secondary effect not comparable in magnitude to the primary effect of sensor size.
Note that the article says
Quote: ...for fixed sensor format, the light collection efficiency per unit area is essentially independent of pixel size...
and
Quote: Noise performance per unit area was seen to be only weakly dependent on pixel size.
plus
Quote: if anything, smaller pixels perform somewhat better in terms of S/N ratio (while offering more resolution).
which supports what I've written.
