I wonder if anyone else has run across this problem with an SMC-A 50mm f/1.7 or similar lens: the aperture ring doesn't always turn freely. It's okay between f/1.7-f/5.6, but if you try to close it down beyond that it sometimes sticks. Apparently the problem is the mechanism under the little release button that lets you get in and out of the 'A' position; while you hold that button down, you can move the ring to any position.
Optically the lens is fine, and I've experimented with it in the A position on my DL and found it works in all picture modes. But my plan when buying this lens was to use it on an older manual camera, and in that context the aperture ring hangups would be an annoyance.
I'm mechanically inclined, so was thinking about trying to take the lens apart to see if there is anything I can do - but first, has anyone run into the same problem before, and is it a simple fix? If not, the thing to do is to leave it intact, not risk having it fly apart in a thousand pieces on my workbench, and find someone who wants to use it in A-mode on a newer camera.
It would be fine on my *istDL, but I don't need it for that, because I snagged one of the last FA50/1.4 lenses in the world a few weeks ago.
