Well guys, I guess I got inspired after reading this tread, so yesterday I took almost completely apart my old Pentax-M 35mm F2.8 (have had it since it was new) due to the slow aperture, was some grease on the blades (I think it’s known for it’s sticky blades). It wasn’t actually too hard. You first unscrew the front ring with a friction tool and the remove the 3-screws underneath, then the front lens assembly can be unscrewed (turn the focusing ring to the close focus limit for an easy access). Then turn it around and remove the bayonet mount, leave the plastic cover on the bayonet. Now you have access to the rear lens assembly, unscrew it, and now you can access the aperture from both sides. Now from the front unscrew the ring holding the aperture mechanism in place, and remove the screws holding the aperture level in place. The picture below shows the 35mm in pieces, well after reassembly of the pieces the lens is as new again.
After this success started working on my old favourite lens from the film days, the M20/F4. It had also developed a slow aperture during the years, the work flow is basically the same. But I didn’t dare taking the aperture mechanism apart, so I used some electronic cleaning spray on it. It worked very well, the old favourite is back in working order again
Another thing that will cause the aperture to work slowly: is a kind of a step-down ring located between the bayonet and the lens itself. I guess old and excessive amount grease on this ring will make the aperture work slowly as well, both the K28/F3.5 and the K35/F3.5 I have, had this problem. But now both of them have a snappy aperture again. I guess I have to put some light grease on the ring again to relubricate it. The picture shows the K35/F3.5 after the bayonet have been removed.
If any of you need some more pictures of any of these lenses, I can put them on my Flickr page
Regards,
Mike
