Quote: Ron Boggs: Since medium format lenses have approximately half the resolving power of SLR lenses (30-45 lines per mm vs 60-90 lines per mm--depending on who does the testing and what the parameters are). Wouldn't that result in less sharpness than shooting with high quality SLR lenses?
I know that in analog form, since 6x7 system produces a much larger image--4.5x larger than 35mm--you need less magnification to print and thus "buy back" the resolution in reduced magnification to achieve the final print. I get that, but I also realize that digital doesn't translate quite as easily into "final print magnification".
So even if you are only using the center "sweet spot" of the MF glass, if that still has lower resolution than, say a Limited lens, wouldn't the Limited produce much sharper images than the 6x7 lens with adapter? Even "standard issue" DA lenses have higher resolving power than the best 67 lenses and thus should produce sharper images
Ron: I am definitely not someone with technical expertise, but I do have 2 decent eyes and an opinion, so I just did a quick test to put them to work.
I took a shot with my Tammy 17-50mm @ 50mm and f5.6 manually focused. Then by slightly moving the tripod back a little bit to try and offset the tad extra reach my Pentax 67 SMC 55mm f4 lens has, I took another shot @ f5.6 with it.
A quick but careful comparison of the images shows nothing conclusively, except the Tamron renders a bit more underexposed when both lenses are with identical EXIF, something I already suspected about the Tammy.
I manually focused both shots, so there is a margin for error. My first observations do not support that MF lenses, in general, tend to have half the resolving power of good APC glass. I will need to do more shooting, within set parameters, but it is possible that the MF Pentax 55 is sharper than the Tamron 17-50 is @ 50mm. Do you have any thoughts? Does anyone for that matter? I would love to hear and learn more.
I do have a very nice copy of the Tammy. And I believe the resolution figures, though not immediately available to me, are impressive.
