Originally posted by audiobomber That's not been my experience Marc. My tests show the Raynox 250 at 1:1 macro has about 50% of the depth of the D FA 100mm macro. I believe Newarts has some math to show this.
I tried to word what I said in way to not suggest otherwise, but I probably failed. Yes, there may be things about each basic method (closeup lens versus extension tube versus true macro lens) that causes DOF achieved by one method to differ from DOF achieved by a *different* method. I'm still pretty unclear on how/why this might the case, an still wonder to what extent what we're actually seeing is a difference in *how* OOF the OOF part of an image look (just as is the case when comparing different focallengths for the same magnification).
But anyhow, my claim was meant to be narrower - *for a given method* (closeup lens, say), anything you did you increase magnification would decrease DOF. And that this is just as true of extension tubes and macro lenses as it is of closeup lenses.
It's certainly possible that whatever optical qirk that causes the DOF with a closeup lens to appear smaller than that using a macro lens might make the 250 + short focal length to have different DOF than the 150 + long focal length that provides equivalent magnification. But I wouldn't be surprised if the *apparent* advantage is to the 250, just as it is when shooting a 50mm macro versus a 200mm, because of the factor I mentioned of how OOF the OOF areas are. Would be interesting to see an actual comparison.
