06-13-2007, 11:48 PM   #1
Cheap, long-range telephoto lenses any good (how about prime ones)?
I really don't have much money to spend, but I'm finding my DA 50-200mm isn't reaching as far as I'd like in a few cases. I should have picked up a Sigma 400mm f/5.6 prime on eBay when I saw it a month ago for under $300, but I didn't. I've looked at a few of the other options -- Pentax, Sigma, Tokina, etc... of varying 70, 80 to 300, 320, etc... zooms and most people say I will be disappointed by the image quality compared to the DA 50-200mm (i.e., most of what I've read say they will fair no better at 200mm and beyond 200mm they leave much to be desired).
As such, has anyone gone with one of the dirt-cheap, long-range telephoto lenses. You know what I'm talking about, those Phoenix, Quandry, Opteka (sp?), etc... lenses for $100-200. I thought I saw a few that were "primes" -- like 400 or 500mm, and not just zooms. I was hoping that something in a cheap "prime" might do decent enough, as I assume the zooms are rather pathetic in image quality.
Thanx in advance and sorry if this has been asked before.
06-14-2007, 02:07 AM   #2
Whatever you do, do not waste your money on ANYTHING that has the name Opteka on it. Total crap.
I think you will find that the words "cheap" "good" and "telephoto" rarely belong in the same sentence, although I recently picked up a Sigma 70-300 mm lens for about a hundred bucks at a pawnshop that I have gotten good results with.
06-14-2007, 02:19 AM   #3
The Pentax FA 80-320mm is pretty cheap (under $300), so try to go for it if you can find it. It's very sharp for such a consumer zoom, even at 320mm!
06-14-2007, 06:11 AM   #4
Lowell Goudge's Avatar
QuoteOriginally posted by bjsmith Quote
I saw a 500mmF8 tameron mirror lens for $250 cdn, and there are similar lenses on Adorama for about $150 us. they are light weight, can be hand held, have excellent close focus capabilities compared to normal lenses, and providing you don't mind out of focus donuts and no depth of field control they are a reasonable solution.
My own adventure into long lenses came when a store had a closing out sale in 1982 of a 400mmF5.6 vivitar for $160. Great lens but really big. Since then, I have added a celestron C90 telescope (1000mmF8) and a 300mmF4 SMC Pentax which I use with either 1.7x autofocus TC or 2xTC.
all have thier uses, but the 400 mostly sits at the present.
Shop around, you will find bargons
06-14-2007, 08:52 AM   #5
I have a 500mm Phoenix, and in all reality it's worth every penny and then some. Whatever you do don't get their 2x teleconverter.
However I don't use it very often. It's a little tough getting good image quality on anything other than a perfect day.
This pic was taken on it on a cloudy day, and although the subject was fair the background had more noise than I like.
06-14-2007, 09:29 AM   #6
A bit more expensive
I got the Pentax SMC 300mm F4 from KEH. I've found it to be a very good lens. Mine cost almost $300 tho, including shipping. It was EX grade, so you might find it cheaper in a lesser grade. I've found it's IQ to be quite good, many shots from it can be found here:
https://www.pentaxforums.com/forums/post-your-photos/5813-kites-lots-images-some-replies.html
NaCl(a little more that what you want to spend but a good lens)H2O
06-14-2007, 11:43 AM   #7
If you want quality, then you'll have to go the prime route. But some of those may be quite expensive. I've heard good things about the Tamron 70-300mm. The only other lens I can think of is the Sigma 100-300 f4. I don't know if they make it in Pentax mount.
06-14-2007, 12:36 PM   #8
QuoteOriginally posted by neighhoma Quote
They do, but it's not cheap: Sigma - Lenses
06-14-2007, 12:58 PM   #9
BTW, in case you didn't notice my sig, this will be for a Pentax K100D dSLR.
QuoteOriginally posted by Mo Quote
I looked at the FA 80-320mm f/4.5-5.6, but came away with several people telling me the image quality beyond 200mm left much to be desired.
At least that's what most said after having also used the DA 50-200mm and shooting at its 200mm extreme (which I do right now).
I.e., they said it won't give me anything I want to use beyond 200mm than the DA 50-200mm.
I don't need a zoom, a prime would be great, of which I was hoping the "cheap primes" might be "as good as" a "quality zoom." I'll be using the DA 50-200mm as my primary lens, and only pulling out when I'm going to be shooting at the long focal length consistently, so it can be a prime -- like 400mm or even 500mm. I think 250 or 300mm might be limiting, although I'm not against a solid 320mm.
Not to ask you to do anything for me, but do you have any recommendations?
I.e., links to products at Adorama?
I don't mind that at all.
It'll teach me a lot anyway -- since I can fire off 500+ shots and learn from them.
Yeah, there is a Vivitar 400mm f/5.6 on eBay right now -- $120 first bid with a $170 "Buy It Now" price.
Unfortunately the reviews I found on it sucks, and sucks hard.
That's what I'm trying to do.
QuoteOriginally posted by little laker Quote
Is that sarcasm?
Or does the Phoenix 500mm f/8 prime actually do okay, as long as you realize it's f/8 limitations?
I was hoping a cheap, prime would be tolerable, as long as one realizes its f-stop limits -- like f/8.
I'm not doing a teleconverter period, I'll put a full lens on.
I don't mind being at f/8 and will do it out in daylight or very well light stadiums.
That's all I want it for.
What camera did you use?
I can't seem to bring up the photo -- are there shots posted elsewhere?
QuoteOriginally posted by NaClH2O Quote
Well, it's still only a 300mm.
Yeah, I know, 50% more reach than the DA 50-200mm, but I was hoping for 400mm.
I guess I'm just wishing for a little too much?
Yes, they make the Sigma 100-300mm and 100-400mm in a Pentax K mount, but they are either crappy ($200-400) or costly ($600-1,000+).
If you didn't see my other thread, I bought a Tamron 28-300mm f/3.5-6.3 Model 185D -- what a POS at image quality.
The DA 50-200mm absolutely roasted it at both 50mm and 200mm in image quality -- literally grainy v. sharp.
The DA 18-55mm "kit" and an FA 28-105mm also roasted it at 50mm and 50mm and 100mm as well -- worlds of difference.
I know the Tamron 70-300mm would be better than that Tamron 28-300mm superzoom, but it's still only 300mm in the end.
I'd really like to get to 400mm.
06-14-2007, 01:29 PM   #10
BJ
aside from giving me credit for someone elses posts,
if you go to the Adorama site and search for pentax mount 500mm you will find it.
regarding vivitar lens, I am not sure I agree with the other reviews, but everyone will have their own opinion.
like every lens I have good shots and bad shots with it.
Best performance is on a tripod,
I haven't used it much since I got the 300mmF4 and the 1.7x AF TC which I used extensively on film with my PZ1.
Although out of your intended price range, I really love the sigma 70-200 F2.8 and the 1.4x TC as this gives me 100-300 mmF4 autofocus.
given the crop factor and speed on digital it works pretty well
06-14-2007, 01:38 PM   #11
Lenses
At Adorama in the used section there is a 400 sigma and a 500 tamron used for under 200 each. Might be what you are wanting.
Kenn
06-14-2007, 01:59 PM   #12
BJ
Sorry about that. I think I've since corrected it.
Yeah, I noted a pair of f/8 mirror lenses -- 400mm and 500mm.
Any comments on those specific lenses?
Here's the $120/$170(Buy-It-Now) on eBay:
Pentax K Mount Vivitar 400mm F5.6 for K10D K100D
Of course.
Shake Reduction only goes so far at longer ends.
QuoteOriginally posted by KennJ Quote
Lenses
Kenn
Yep, f/8 mirror lenses. Anyone have any comments on those specific lenses?
Conclusion: I'm thinking of just going with the Vivitar 400mm f/5.6 on eBay. The "haze" comment does scare me a tad though.
06-14-2007, 02:50 PM   #13
The Sigma 400mm is a 5.6 and not a mirror lens. I have one and it is a workable model. Has a bit of CA and not the greatest bokha but for the price it aint bad.If you would like I can shot you a few pics from mine to check out. Just pm an addy if you want a few shots.
Kenn
06-14-2007, 03:02 PM   #14
Yep, that's why I'd rather buy it than the f/8 mirror lenses.
I don't expect or really need great bokha out of a telephoto (at least non-macro), and CA is not a killer.
Overall sharpness and image quality is more of a consideration.
Oh definitely!
We've only got 3 hours left so if you're going to take a few shots, please do so soon.
If you can just crop out the center (or where ever you feel is best) at 1:1 pixel to give me an idea of that sharpness at that long range, that would be best.
Thank you very much for the offer regardless of whether or not you get back to me in time!
06-14-2007, 03:47 PM   #15
I was serious, the Phoenix is pretty good for it's money, it just doesn't compare to my Sigma 135-400 I got a few days later.
If I didn't have the Sigma I'd probably use it every time that I went birding.
I'm sorry about the link. I forgot that my server and this one don'e seem to be best friends, so my pic's don't always appear
Here's a link to the pic
http://www.bcscenicwonder.com/plantsanimals/animals/birds/IMGP8308.jpg
and a link to the full sized picture to give you a really good idea what it's like
http://www.bcscenicwonder.com/plantsanimals/animals/birds/IMGP8308fs.jpg
another full sized pic with it
http://www.bcscenicwonder.com/plantsanimals/animals/birds/IMGP8365fs.jpg
That was my first time ever using the lens, if I took some time I could probably better those images
Oh, I'm also using a Pentax K100D and love it
Edit, I had the Osprey in focus and snapped pic's until it flew behind some buildings until it flew behind a tall building. That's when I realized that it was over 1/4 of a mile away. I don't think that I could do that with my Sigma.
200mm, 50-200mm, da, image, k-mount, lenses, pentax lens, quality, sigma, slr lens, telephoto
HowTo long range telephoto shots falconeye Photographic Technique 3 04-08-2010 04:32 AM
Will Pentax bring out super long prime lenses again ? lesmore49 Pentax SLR Lens Discussion 3 08-28-2008 09:39 PM
Cheap long lenses? gamgee Pentax SLR Lens Discussion 15 07-29-2008 02:02 PM
Why long range lenses for landscape shots? Photochop Pentax SLR Lens Discussion 5 04-03-2007 07:09 PM
All times are GMT -7. The time now is 02:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
