They sell
custom made silicon bracelets on ebay. Cost is about $3.95 each if you order single quantities, and about
$13 for five if you buy in the larger quantity. I bought the solid which means the silicon is embossed. They also sell bracelets where the wording is painted/printed on the bracelet. The print tends to wear off over time on these. I bought the adult, 8 inch size
With the embossed, I figured I could paint them myself which I did with a couple of metallic Sharpies. This isn't ideal, but it works well enough for me. I used silver and gold. The gold on the black bracelet comes out a darker more orange gold than a real gold. It is OK, as it is a little more understated than the silver. I don't think the color will stay on, but I can touch them up whenever I want.
I'm using these on the Tamron 18-250mm, and Tokina 80-400mm to stop the zooms from creeping. I also use these on flash heads to hold different light modifiers. If you use a better bounce card, these work really well and leaving them on the flash isn't too trashy. Well at least for me, now were did I put my leisure suit. I hope my wife hasn't thrown it in the dumpster again.
Thank you
Russell
