I think that everyone else has hit pretty much on the high f stop values. f4 is the sweet spot for the lens (center) and you get a lot of falloff in resolution by f11. See the Photozone link in the resolution section. So I would keep it at f4 for maximum sharpness in the center and no greater than f8. I see you have kept the ISO at 200 which it the lowest ISO for the camera (I believe). I would maintain this in order to keep the noise low (it will elongate the shutter time). At these f stops (f4-f8) you still retain depth of field from between 50 to 25 feet out to infinity. So, for landscapes I really see no need for anything over f8 and possibly a bit less.
The other item is shutter speed, and the Kr/kx has a high capability 1/4000 - I think. So, let the camera figure it out by fixing the f stop and ISO to your advantage.
The other thing you can do is to work with the light. Early morning and late afternoon or early evening, you can probably get rid of the background haze, get the sun glinting off the buildings, with some building lights, a deep blue sky (see the golden hour calculator below). Also, this will get some deep shadow angles within the landscape (and buildings) and also help give it the feeling of some depth.
The other thing is a tripod if you are going to go into the evenings, along with an external shutter release - your only option for the Kx/Kr is the IR release (set up the camera body for the first click to open and the second click to close if you go with either a bulb setting or bracketing).
Another thought - with the harshness of the sun, a lens hood may help in terms of negating lens flare - although in some shots lens flare can add to the shot in some settings. Then again, the lens coatings on these new lenses are very good. You might just have to work at trying to get some lens flare....
