Originally posted by Rnovo As for HDR I have found that the K5 exposure bracket feature will only give you its own result: you don't have control on each of the 3 (or 5) exposures. If you select +/- 1 EV and you want a fixed aperture, you won't get it. The camera will only give you the 1EV (2, or 3 EV...) bracket so if you need critical DOF, for example, you won't get it. It's the same for shutter speed - you can't get a fixed shutter speed with different apertures...
There is an obscure solution for this...
- Press the "Menu" button
- Go to section 5 of the "camera" menus
- Go into "E-Dial Programming"
- Go to page 2 of it's menus
- For "M" mode, set the Green Button to "Tv Shift"
This will mean that pressing the Green Button in M mode will only adjust the shutter speed, but it ALSO means that any Exposure Bracketing you do in M mode will also
only adjust the shutter speed to get every EV you specify! (Weird that they are connected, but that's how it works.) BTW, you only want different shutter speeds for each exposure... changing the aperture messes up not only depth-of-field, but also focus, chromatic aberrations, vignetting and other things you should correct for in your DA 10-17mm shots.
Originally posted by Rnovo I have a mac so I can't use windows software as it was suggested.
Then you're in luck. Try
Bracketeer (Mac only) to use high-end image fusion on your exposures, rather than HDR. It will give you much more "natural" results, without all the fussiness of actual HDR. You should fuse the exposures together first, then hand them off for stitching... if you use the batch function of Bracketeer, they will look identical at the overlaps!
