Originally posted by Adam I just took a look at it, and it's a shame
it doesn't let you drag it with you mouse. I can try to code up a fancier comparison tool later on, or look at other options that are already out there, as I'm sure there are plenty
Drag images into the tool for comparison or drag the vertical line for comparison? You can grab the vertical comparison line in the center (the green section of the vertical bar) via a left mouse button depress and drag the comparison bar left and right in order to compare different areas of the images..
It took me about an hour to find this tool, and I had a pretty good idea as to what to look for. That said, I may have been a bit too familiar with image exploitation and other folks may be describing this a bit differently than how I describe it.
I am anticipating that with the excellent reception that the IIs has received, that Pentax will probably produce a 2 body set going forward - one with and one without the AA filter (and possibly other similar approaches).
This tool approach would also be useful in comparing 2 images from similar lenses (especially with the scaling capabilities), i.e., 31 Ltd and the Sigma 30mm.
