Ok, a few people have asked my about my "Photo-Cart" and here it is.
My Cart started with a Northern Tool Cart -
Northern Tool & Equipment Steel Cart — 34in.L x 18in.W, 400-Lb. Capacity, Model# NTE110 | Hand Pull Wagons| Northern Tool + Equipment
I used a measured and cut sheet metal tray, riveted to the frame of the cart, and covered it with thin "sticky-back" foam from a craft store. I then used some Home/Hardware Store Bicycle holders on one side to hold my Slider and a Monopod. I also made some custom straps to hold a tripod to the other side of the cart.
I then made a custom wheel brake so that it didn't roll around.
I use a Think Tank Airport Security 2.0 to hold all my gear. Whatever space is left over, holds my WalkStool and other bits an pieces.
This cart is small enough to use in Wheelchair accessible places and is small enough to not attract attention.
It is also small enough to fit in the back of our Nissan Rogue/Qashqui and Armada
Enjoy.
The cart
A close up of my custom wheel-brake device
A close up of my custom wheel-brake device as I store it at the end of the detachable handle (that way, I never lose it and it's always there).
A close up of the wheel that I modified to use the custom brake device. Notice that I have taken the cotter pin out of the axle and replaced it with a small bolt.
Another view of the "brake wheel" and how it works.
The mechanism works pretty well.
Here is how the brake looks installed on the wheel
The bicycle hangers for the slider and monopod (or tripod)
My custom straps
What the regular cotter pin wheel looks like
All loaded up ready to go.
I still have more room for extra stuff
Side view with my Manfrotto 3021Pro (055) tripod, 555B leveling post and ProMediaGear Gimbal. Sometimes I take the Gimbal off and put it inside the cart.
Another view.
How the Think Tank Airport Security 2.0 opens. I have a TON of gear inside!
Another view
This cart works very well when you need to go over rough gravel or grass. I've never had a problem taking this to places where they allow wheelchairs.
It's heavy, sure, but with my WalkStool, I can set up in a location that others can't, and snap away.
It's definitely one of my "Secret Weapons".
