The hills are alive with the colors of azaleas.
From the very close to the relatively far away. All taken with the DS C&C welcome as usual.
A rare yellow azalea, taken on a windy day. Wind and floral close ups don't mix. FA 50mm 1.4 f3.5 at 1/750
I had just started getting a macro on this plant when the sprinkler system went off. I beat a hasty retreat and had to wait 20 minutes till the system turned off! Tamron 90mm macro f11 at 1/180
Loved the play of light over this one. Tricky exposure, white flowers and bright highlights, but I guessed right. Zenitar 16mm Fisheye 1/350 aperture unknown.
Liked the colors of this one. Zenitar 1/125
They had paths winding thru some of the larger bushes. The Zenitar was invaluable in capturing the large variety of colors. Zenitar 1/180
Another path, another wide photo. I'm so glad I have this lens! Zenitar 1/1500
The one problem with azaleas is that the blossoms are quite reflective, if you've got mixed sun and shadow it's hard to avoid overexposed areas if you are trying to capture large scenic areas. Somehow closer in you don't get the blown highlights. Zenitar 1/125
From the top of the ridge, you can see the path entering from the center left, then it disappears between the bushes. Zenitar 1/125
Looking back up towards where I was standing on the last shot. However my camera in that last shot was pointed over to the right of this photo, gives you a bit of an idea how large the area was that was covered with color. Zenitar 1/500
edit: almost forgot; you can find more shots here:
saltwater : photos : Azaleas - powered by SmugMug
NaCl(it was like music for the eyes)H2O
