Pentax Lens Review Database » Pentax M42 Screwmount Lenses » M42 Screwmount Normal Primes
Auto-Takumar 55mm F1.9 Review RSS Feed
1 20,986 Tue October 26, 2010
100% of reviewers $3.00 9.00
Auto-Takumar 55mm F1.9 Auto-Takumar 55mm F1.9
Description:
The F1.9 55mm lens only existed in the Auto-Takumar series and it is a very rare lens.
Image Format
Full-frame / 35mm film
Lens Mount
M42
Aperture Ring
Yes
Diaphragm
Semi-automatic
Optics
6 elements, 5 groups
Mount Variant
M42 Stop-down Pin
Check camera compatibility
Max. Aperture
F1.9
Min. Aperture
F22
Focusing
Manual
Min. Focus
55 cm
Max. Magnification
Filter Size
46 mm
Internal Focus
APS-C: 29 ° / 25 °
Full frame: 43 ° / 36 °
Hood
Case
Lens Cap
Coating
Weather Sealing
Other Features
Diam x Length
Weight
175 g
Production Years
1958 to 1959
Engraved Name
Auto-Takumar 1:1.9 f=55mm
Reviews
User reviews
Notes
Very rare. Only sold by Sears with a rebadged Pentax (Tower 29). Optics could be same as the 1:1.8/55
Variants
Some sources mention that an all black version exists.
Features:
Manual FocusAperture RingFull-Frame SupportAdapter needed for DSLRsDiscontinued
Add Review of Auto-Takumar 55mm F1.9
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-1 of 1
2 users found this helpful
Lens Review Date: October 26, 2010 I can recommend this lens: Yes | Price: $3.00 | Rating: 9
Pros: Sharp! All metal build. Clear glass with large Aperture.
Cons:
I found this lens on a Tower Camera in a garage sale. It was in a leather case with the camera so It was well preserved.
Of interest is the following:
1. Ten bladed Aperture f/1.9-f/22.
2. Aperture ring is on front of lens, and an infinite number of Aperture values can be selected (between stops).
3. Filter size is 46mm (Forty-Six).
4. The lever is to 'Pre-Charge' the Aperture. To obtain the widest Aperture (for focusing clarity) you pull the lever down with your left index finger until it locks the Aperture wide open. You can then select any Aperture you like, and when the Shutter is released the standard M42 'Pin' on the back of the lens is pressed with the 'Paddle' in the lens bay releasing the locked Aperture. This of course works only with the old film cameras. However, I use this lens more than my other Takumar's because unlike most Takumar lenses you can set a small Aperture and use the lever to 'hold' the Aperture open wide enough to focus and release it prior to opening the shutter. The lever is spring loaded and moves the Aperture towards full open the further you pull it. However, if you go all the way to the 'lock' position you must remove the lens and press the pin to free up the Aperture blades.
5. Focusing feels very similar to my other Takumar lenses.
6. Uses standard M42 adapter on K mounts.
7. All metal, superb build quality.
8. Very sharp, even at f22.
I haven't used it all that much because of the focal length. As small as it is it should work well with a FF Pentax (or other brand) DSLR with an adapter. I don't think there is any coating on the lens. Sometimes in the right light the glass appears very slightly gold like the Tak 50 f1.4, which may mean there is some type of coating, but I can't confirm it. I use a 46mm-49mm adapter so I can use 49mm filters.
Overall I really like the lens, but you may get similar quality photo's from the more readily available standard Takumars.
Excellent glass.
All times are GMT -7. The time now is 03:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
