Pentax Lens Review Database » Pentax M42 Screwmount Lenses » M42 Screwmount Telephoto Primes
Bellows-Takumar/Super-Multi-Coated Bellows Takumar 100mm F4 Review RSS Feed
Sharpness
 9.3
Aberrations
 8.3
Bokeh
 8.0
Handling
 7.3
Value
 8.8
7 36,678 Sun October 6, 2019
100% of reviewers $120.00 8.43
Description:
This lens is designed to be used exclusively with the macro bellows as it has no focusing mechanism of its own. The lens came in two versions witch were optically identical except for the lens coating: the latest version of the lens received multi-coating.
The lens was reissued in K-mount.
First version (see photo to the left):
Bellows-Takumar 100mm F4
Image Format
Full-frame / 35mm film
Lens Mount
M42
Aperture Ring
Yes
Diaphragm
Preset, 8 blades
Optics
5 elements, 3 groups
Mount Variant
M42 Plain
Check camera compatibility
Max. Aperture
F4
Min. Aperture
F22
Focusing
Manual
Min. Focus
Max. Magnification
Filter Size
49 mm
Internal Focus
APS-C: 16 ° / 14 °
Full frame: 24 ° / 20 °
Hood
Case
Lens Cap
Coating
Weather Sealing
Other Features
Diam x Length
54.5 x 36 mm
Weight
139 g
Production Years
1964 to 1971
Engraved Name
Bellows-Takumar 1:4/100
Product Code
360, 43600
Reviews
User reviews
Notes
The lens is for use with a bellows unit and has therefore no focusing ring.
Variants
1: Bellows-Takumar 100mm F4
2: Super-Multi-Coated Bellows-Takumar 100mm F4
Second version (see second photo):
Image Format
Lens Mount
M42
Aperture Ring
Yes
Diaphragm
Preset, 8 blades
Optics
Mount Variant
M42 Plain
Max. Aperture
F4
Min. Aperture
F22
Focusing
Manual
Min. Focus
Max. Magnification
Filter Size
49 mm
Internal Focus
APS-C: 16 ° / 14 °
Hood
Case
Lens Cap
Coating
SMC
Weather Sealing
Other Features
Diam x Length
54.5 x 36 mm
Weight
139 g
Production Years
1971 (start of production)
Engraved Name
Super-Multi-Coated BELLOWS-TAKUMAR 1:4/100
Product Code
43601
Reviews
User reviews
Notes
Variants
Features:
Manual FocusAperture RingFull-Frame SupportAdapter needed for DSLRsDiscontinued
Price History:
Add Review of Bellows-Takumar/Super-Multi-Coated Bellows Takumar 100mm F4
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-7 of 7
1 user found this helpful
Lens Review Date: October 6, 2019 I can recommend this lens: Yes | Price: $100.00 | Rating: 10
Pros: very sharp macro lens / with focal reducer excellent
Cons: very small CA's
Sharpness: 10    Aberrations: 9    Bokeh: 10    Handling: 9    Value: 10    Camera Used: k-s1 k200d k-x
with bellows and achromatic focal reducer (self made by a single binocular front lens 8x30 fitted into a PK macro ring) will give excellent sharpness at f 8-11 and minimization of CA's !
++/+ excellent sharpness up to magnification 1:2, very good/exc. 1:1, good/very good 2:1 at f 8- 11
***** no reduction of corner sharpness as usual by modern AF lenses *****
++ neutral color rendition
++ high contrast, if bellow has been anti-reflex-fitted with dark clothing, in order to reduce flare, totally
++ very few CA's - with achromatic focal reducer no CA's visible
++ no vignetation
9.5 points totally
highly recommended !
Loyal Site Supportaxian
Lens Review Date: March 5, 2014 I can recommend this lens: Yes | Price: N/A | Rating: 6
Pros: Sharp
Cons: Aperture blades are far from round, can be a hassle to use.
Sharpness: 9    Aberrations: 7    Bokeh: 4    Handling: 5    Value: 5    Camera Used: Multiple Canon EOS
The biggest positive of this lens (in combination with a bellows) is the ability to focus from infinity to beyond 1:1 without changing your setup. Want to walk around a nature preserve and take a super close up of a flower followed by a shot of a far-off bird without switching any gear? This is a good combo for you. The second best attribute is that it's quite sharp.
Tip: Put the Asahi Pentax Variable Close-Up Ring and Extension Tube #2 on back of this and you've instantly got a lens that can infinity focus without all the bulk of a bellows.
Another reviewer mentioned that the aperture blades on this give nice stars (the star spikes peak around f7-10). If you want stars, great! Since this primary purpose of this lens is macro, and I usually don't want stars in my macros, this is a negative for me. If I want to induce stars, I prefer to stick an aperture mask on the front of a lens so I can precisely control the effect. It's all a matter of taste though, and some people will love it. Even though they have the same optical formula, I can definitely say you will get more bokeh 'flavor' with the Takumar-Bellows when compared with the S-M-C 4/100.
If you want a smaller, more convenient setup you might consider the S-M-C 100mm f/4 macro instead. I find it more practical, and if you need more than 1:2, you can always pop extension tubes on the back.
2 users found this helpful
Lens Review Date: May 5, 2013 I can recommend this lens: Yes | Price: N/A | Rating: 9
Pros:
Cons:
Sharpness: 9    Aberrations: 9    Bokeh: 9    Handling: 7    Value: 10
I used mine extensively on my spotmatic F. I used it as a short telephoto as well as macro. I was able to balance everything including a Rollie hammer head flash, focus and use the ring to stop down to the required aperture. My motivation was to outdo everyone else with their expensive nikon gear and hasselbads with their wildlife photos. The later was easy than you might expect because they had real trouble with the back ground composition.
Over the years I have taken some great shots, but my eyes are becoming dimmer and I depend heavily on autofocus. I still pull the lens and bellows out to do macro work. For some reason it seems a lot brighter in the viewfinder than my old takamar F5 50mm macro.
The lens and bellows is a lot of fun if you can get hands on them. I had a t mount that seemed to easily fit on the bellows.
Do not use the pentax m42 adaptor. It locks onto the camera and you won't be able to screw off the bellows.
Lens Review Date: January 16, 2013 I can recommend this lens: Yes | Price: N/A | Rating: 9
Pros: very sharp
Cons: slow to use
Sharpness: 9    Bokeh: 9    Handling: 8    Value: 10    Camera Used: k7
I know that using a bellows unit may be a bit a slow process, but as a studio tool in photography its priceless,
But for outdoor or hand held photography I think a Macro lens of the Pentax kind would be easier and just as sharp.
Lens Review Date: May 22, 2011 I can recommend this lens: Yes | Price: $140.00 | Rating: 9
Pros: Star shaped blades (bellows), goes at more than 1:1
Cons: Bellow needed
I'm surprised that no one said something about the aperture blades of the Bellows : it gives a nice 8 peaks star that can be useful to obtain a great bokeh. I've used the lens up to something like 5:1 (two bellows + 2 extension rings sets) and it is quite sharp for a such reproduction ratio !
I recommend to use this lens with the Pentax "Bellows unit" : it will go a bit further than infinity, a bit further than 1:1 and it is light enough to use it handheld in macro.
Samples : http://kajiwara.weebly.com/takumar-1004.html
Lens Review Date: January 14, 2011 I can recommend this lens: Yes | Price: N/A | Rating: 8
Pros: nice lens
Cons: you need a Pentax bellows!
I bought this in the early 70's, and I got it with the Pentax bellows, and the slide copying addition. Nice lens, fully manual, screw mount! Gave it away, a few years ago, but I don't regret it a bit, as Tamron 90 is so much better, and as good as a macro lens! Plus much simmpler to use, than the Bellows 100!
Lens Review Date: March 21, 2009 I can recommend this lens: Yes | Price: N/A | Rating: 8
Pros: Sharp, build quality
Cons: Practicality - needs bellows unit or extension tubes
This lens is rather difficult to review. Optically it is a great lens. It's the same as the 100mm f/4 macro. As such it deserves a similar rating.
However, you cannot use it as-is. It needs at least 37mm of extension to focus to infinity (minimum bellows length) and 138mm of extension to get to 1:1 reproduction.
As such you probably won't use it as a walkaround macro.
Now can you fault a Bellows-Takumar for needing a bellows unit?
I'm still not sure, but I've deducted 1 point to reflect this dilemma.
Particularly recommended for your (tabletop) studio work.
All times are GMT -7. The time now is 12:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
