Pentax Lens Review Database » Film Era Pentax K-Mount Lenses » Non-SMC Pentax Zoom Lenses
Pentax-F 70-200mm F4-5.6 Review RSS Feed
Sharpness
 8.2
Aberrations
 7.8
Bokeh
 8.0
Handling
 7.0
Value
 9.5
Focusing
 1.0
7 51,932 Fri December 6, 2019
100% of reviewers $55.80 7.29
Description:
This is an autofocus zoom lens without SMC coating. It is identical to the TAKUMAR-F 70-200mm F4-5.6.
Image Format
Full-frame / 35mm film
Lens Mount
Pentax K
Aperture Ring
Yes (A setting)
Diaphragm
Automatic, 9 blades
Optics
10 elements, 8 groups
Mount Variant
KAF
Check camera compatibility
Max. Aperture
F4-5.6
Min. Aperture
F32-45
Focusing
AF (screwdrive)
Quick-shift
Min. Focus
110 cm
Max. Magnification
0.25x
Filter Size
49 mm
Internal Focus
APS-C: 23-8.2 ° / 19-6.9 °
Full frame: 34-12 ° / 29-10.3 °
Hood
No dedicated hood
Case
No dedicated case
Lens Cap
Coating
Weather Sealing
Other Features
Diam x Length
71 x 99 mm
Weight
555 g
Production Years
1988 to 1991
Engraved Name
PENTAX-F ZOOM 1:4-5.6 70-200mm
Reviews
User reviews
Notes
No SMC coating
Variants
Also sold as Takumar-F 70-200mm F4.5.6
Features:
Screwdrive AutofocusAperture RingAutomatic ApertureFull-Frame SupportDiscontinued
Price History:
Add Review of Pentax-F 70-200mm F4-5.6
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-7 of 7
Lens Review Date: December 6, 2019 I can recommend this lens: Yes | Price: N/A | Rating: 1
Pros:
Cons:
Sharpness: 7    Aberrations: 6    Bokeh: 7    Handling: 1    Camera Used: K-30    Focusing: 1
This lens makes extremely loud and grusom sounds. Unbearable!!! The only thing this lens deserves is a hammer :-D
Lens Review Date: April 27, 2017 I can recommend this lens: Yes | Price: $50.00 | Rating: 8
Pros: sharpness at 70-135mm, low aberrations
Cons: sharpness 200mm, just a bit noisy
Sharpness: 8    Aberrations: 9    Bokeh: 8    Handling: 8    Value: 9    Camera Used: Pentax K-50
This zoom is good (very good, I'd say) at the shortest focal length, bad at 200mm; I have tested it against two others. The work is not professionally done but may help, there is a lot of full-crop samples...:
http://www.rustichelli.net/Hobbies/Photography/LensTests/Zoom-for-Pentax-K-g...group-test.php
Good reading!
1 user found this helpful
Lens Review Date: March 29, 2015 I can recommend this lens: Yes | Price: $40.00 | Rating: 9
Pros: light weight, cheap, sharp
Cons: none
Sharpness: 9    Aberrations: 9    Bokeh: 8    Handling: 10    Value: 9    Camera Used: Pentax K3
I like this lens because it does not have the smc fungus growing coating . I have noticed most of the older pentax lens with the smc coating have fungus growing from the coating . I have found on my lens that between f8 and f13 is the sharpest at 200mm zoom . Here is a squirrel about 15 yards away. 200mm, 1/250, f13, iso 800. As shot. no sharping . Pentax F 70-200 f4-5.6 by myridevlx600, on Flickr
Lens Review Date: January 15, 2015 I can recommend this lens: Yes | Price: $29.00 | Rating: 8
Pros: Sharp at F8, Nice colors, CHEAP, light, quick AF
Cons: AF kicks, loud, not very pretty
Sharpness: 8    Aberrations: 7    Bokeh: 8    Handling: 8    Value: 10    Camera Used: K-5IIs
Great zoom for $29 USD.
Where I live there are very few used Pentax lenses, so I buy stuff on ebay.
In this case, the lens was $29 and shipping was $20, and I'm happy overall with the lens and the price.
The picture below was shot at F8, 1/125 s, 200mm. Not much PP, in Lightroom +9 on contrast, -30 on highlights, -11 on Shadows, +7 whites, -5 blacks.
No sharpening
An update after almost two years. I had a lot of fun with this lens. If you know the limitations, it can produce pretty solid results.
Today, I reverse mounted it (49mm thread adapter to PK) and it produces some nice macro shots.
Here is a sample:
Lens Review Date: November 14, 2012 I can recommend this lens: Yes | Price: N/A | Rating: 9
Pros: Sharpness, quick autofocus
Cons: A bit loud autofocus, tiny focal ring, does not retract all the way like SMC version
Sharpness: 9    Aberrations: 8    Bokeh: 9    Handling: 8    Value: 10
I think Pentax-F 70-200 4-5.6 is almost identical with Takumar F 70-200 4-5.6 in terms of lens formula, elements and mechanism like barrel retraction. I own the latter so I also post my comments here. If you get a good copy and stay a bit away from 200mm, it is a hidden gem. The lens is reasonably sharp and has nice bokeh. Shooting with hood is recommended.
Lens Review Date: May 11, 2010 I can recommend this lens: Yes | Price: $80.00 | Rating: 8
Pros: Good sharpness, accurate AF, virtually nil CA, solid build
Cons: some AF hunting in low light.
Firstly, I have both the Pentax-F 70-200 and the SMC Pentax-F 70-210 and they are equally sharp, both have excellent resolution, and virtually nil CA.
Very many of the SMC Pentax-F 70-210 I have seen seem to be fungus affected, it seems to be a common problem, but the non SMC Pentax-F 70-200 doesn't seem to have this problem.
The lack of SMC really doesn't affect the colour and contrast rendition all that much,and shooting with a good lens hood takes care of any flare issues too.
This lens also just seems a little better balanced in the hand (IMO of course).
Very sharp all the way out to 200mm, I highly recommend this lens, a good lens at a bargain price .
Cheers
John
Lens Review Date: May 19, 2009 I can recommend this lens: Yes | Price: $80.00 | Rating: 8
Pros: Great contrast, sharp, great color from 7-200 with all "A", AF lens
Cons: No SMC
I'm very happy with this lens
Some images from this lens
All times are GMT -7. The time now is 07:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
