Pentax Lens Review Database » Film Era Pentax K-Mount Lenses » Pentax K-mount Teleconverters and Adapters
Pentax Adapter K for 645 Lens (645 to K mount) Review RSS Feed
4 32,855 Fri June 5, 2020
100% of reviewers $155.00 10.00
Description:
This is an adapter allowing you to use Pentax 645 mount lenses on K-mount bodies, including DSLRs as well as film SLRs.
You will have to use stop down metering as the adapter neither has aperture contacts nor an aperture stop down lever.
Autofocus is not supported. AF lenses will have to be focused manually.
Image Format
Full-frame / 35mm film
Lens Mount
Pentax K
Light Loss
0 stops
Magnification
1x
Optics
0 elements, 0 groups
Mount Variant (Rear)
K
Mount Variant (Front)
645 AF
Focusing
Manual
Coating
Weather Sealing
Case
Diam x Length
Weight
0
Production Years
(in production)
Notes
Engraved name: PENTAX ADAPTER K FOR 645 LENS
User reviews
This adapter allows for mounting Pentax 645 lenses on a K-mount camera.
The only exposure modes supported are M and Av with stop down metering, and Bulb. The adapter has no aperture stop down lever and no lens information contacts.
The adapter can be stacked with the 67 to 645 adapter thus allowing Pentax 6x7 lenses to be mounted on a K-mount camera.
Features:
Full-Frame Support
Price History:
Add Review of Pentax Adapter K for 645 Lens (645 to K mount)
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-4 of 4
Lens Review Date: June 5, 2020 I can recommend this lens: Yes | Price: $90.00 | Rating: 10
Pros: Tight fit, excellent baffling, a must-have accessory.
Cons: None.
Pentax K1 mounted on a 645 FA 400 mm f/5.6, Av mode with stop-down metering. Picture taken from 1 kilometer away.
Lens Review Date: December 23, 2019 I can recommend this lens: Yes | Price: N/A | Rating: 10
Pros: Build quality, compatibility.
Cons: Knob hits mirror box on some DSLR camera models.
If you happen to have both systems, this does the trick with the best absolute fit you can find. The only thing you have to keep in mind, is that the rotation lock knob can hit the mirror box while attaching it to some DSLRs. I learned that the hard way.
1 user found this helpful
Lens Review Date: December 5, 2011 I can recommend this lens: Yes | Price: $125.00 | Rating: 10
Pros: sturdy, useful
Cons:
Excellent adapter, which I've used frequently. It is solid, and allows to use the excellent range of 645 lenses to be used on the digital cameras. No complaints.
I paid either 100 or 150$, I cannot remember to be honest, so I averaged it. It came from a forum member and was well looked after.
Lens Review Date: September 6, 2010 I can recommend this lens: Yes | Price: $250.00 | Rating: 10
Pros: build quality
Cons: none
I paid a ton for this directly from Pentax, but I wanted it fast. It was on backorder everywhere else. It is a solid piece of equipment that should last forever. I use it to mount my FA645 120mm macro and FA645 80-160mm on my K-7.
All times are GMT -7. The time now is 08:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
